Old 04-03-2012, 07:17 PM   #1
carlos gallery
Drives: yaris
relay problem
Hi Guys, I hace a Yaris and last night using the lighter to fill a flat tire it when off and the p/s,check engine,air bag light,a/c all that turn on.And the no signal light work I know is a relay. Because i check all fuse with a multimeter and the are ok. thank you
carlos gallery is offline   Reply With Quote
Old 04-03-2012, 09:23 PM   #2
The lighter runs off the 15A CIG fuse in the under hood fuse panel. From there it goes through the normally closed contacts of the ACC CUT relay (which is located behind the change cup on the lower left dash). That gets fed by the AM2 fuse (which is in the under hood fuse panel).
Based on the symptoms, I would recheck the AM2 fuse.
Old 04-04-2012, 05:14 AM   #3
carlos gallery
Drives: yaris
Thank you CTScott.
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 03:42 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
