Old 06-07-2012, 05:23 PM   #1
Archangel1183
Drives: Frontier
Rear Wheel Shims... How do they work?
Hey guys,
I had a question. When you order a Rear Camber Shim Kit, Does it come with one shim or a few shims? In the picture it shows 3. If it comes with 3, are they different sizes in thickness?
I'm guessing it needs to be installed at the alignment shop so they can install the one that's needed?
I'm planning on lowering my XA soon and was wondering how it works and if I should do the work myself.
Thanks
Archangel1183 is offline   Reply With Quote
Old 06-07-2012, 06:19 PM   #2
vten
I received 2 of single shim in the package, I'm not sure how to put it on since I have the rear discs conversion .... So I'll let my local shop to do the installation.
Old 06-07-2012, 06:56 PM   #3
Archangel1183
Drives: Frontier
2 Single Shims? How would they know how thick you need them or how many degrees off the camber would be? Wouldn't a thicker shim be needed if the car is lowered say 2" opposed to 1 inch?
Old 06-07-2012, 07:20 PM   #4
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
if you are going to get a shim kit for the rear your best bet is the SPC brand #75800 EZ shim -1.5 to +1.5 degree adjustable
corrects camber and (or) caster issues
OTA'sTOY is offline   Reply With Quote
Old 06-07-2012, 07:35 PM   #5
Archangel1183
Drives: Frontier
Darn. I ordered the Eibach Kit. They use the same picture on various websites.
What's the difference?
Eibach
http://mudflaps.com/i-7234562-eibach...amber-kit.html
SPC
http://www.fastscions.com/spc-perfor...006-75800.aspx
They also seem to have the Same model number (SPC 75800 VS Eibach 75800K)
Old 06-07-2012, 07:42 PM   #6
Archangel1183
Drives: Frontier
Did a little more searching. I found some info on Eibach.com, I entered part number 5.75800K and found a downloadable PDF. I searched the part number on the PDF and found:
"5.75800K Rear + / - 1.50". Looks like it's the same part offered by SPC.
Old 06-07-2012, 07:49 PM   #7
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
same thing
Old 06-07-2012, 08:06 PM   #8
Archangel1183
Drives: Frontier
I thought so. I'm gonna have the Alignment shop install them. Thanks
Old 06-08-2012, 12:21 PM   #9
Archangel1183
Drives: Frontier
Does anyone have their Yaris dropped 2" without any camber kit at all? I'm itching to install my Sportline springs but the F&R Camber kit are on backorder for about a week.
Old 06-09-2012, 02:28 AM   #10
Archangel1183
Drives: Frontier
I installed them without the camber kits and it's not a huge difference. I'm still going to have it aligned when I get the kits.
Old 06-12-2012, 08:01 AM   #11
33OH
Drives: '08 Yaris
I've had mine dropped 2" without camber for about 4 years.
Old 06-12-2012, 10:54 AM   #12
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
It'll be five years in August for mine lowered 2" w/o camber.
Old 06-15-2012, 03:52 AM   #13
Archangel1183
Drives: Frontier
Thanks guys. You convinced me to just install them without the camber kit. I still plan on installing it and having it aligned when I receive it.
Here are some pics I took today.
Old 06-18-2012, 12:26 AM   #14
Kendrik
Drives: 2011 Yaris Sedan
how durable are the camber shims? I mean, how long can you use them before it needs to be replaced since they are plastic? thanks
Kendrik is offline   Reply With Quote
Old 06-23-2012, 05:58 PM   #15
J.A.R.V.I.S.
war machine
Drives: 2012 yaris LE
hey I'm new to the site. just looking over this thread about camber. if anyone has an xb or xa i have a kit that is metal from REALCAMBER.COM if this helps anyone of you out please let me know.
J.A.R.V.I.S. is offline   Reply With Quote
increasing sound insulation? BLOODY_STONE DIY / Maintenance / Service 20 06-14-2011 09:19 AM
Rear toe adjustment...shims?? ozmdd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-15-2009 10:32 PM
