Old 06-09-2012, 08:39 PM   #1
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Grounding kit
So today I installed a grounding kit on my yariii...I did only 2 ground points + starter + body ground
I got the kit from MicroImage...it is a NRG red grounding kit...
Here is a pic of it installed as weel as the radiator hose from MI
I redid the main body ground, the starter ground, one ground on the valve cover and one on the throttle body...
I have to do one other on the valve cover and the alternator one...
DO you have idea of other ground point I should use ?
Interior:ALL red, black roof
Old 06-09-2012, 08:48 PM   #2
packetrace
packetrace's Avatar
Throttle body ground
Old 06-09-2012, 08:49 PM   #3
packetrace
packetrace's Avatar
First Valve cover ground
Old 06-10-2012, 04:25 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
back on the fire wall where the ECU is bolted up on the lower right bolt that is a stud on the fire wall and up front where the headlight are grounded to the frame. that is at least where i put 2 of mine
Old 06-10-2012, 05:41 PM   #5
auxmike
auxmike's Avatar
What are the benefits of doing this guys? Looks like Medusa's hair!
Old 06-10-2012, 06:45 PM   #6
BLH
Drives: 2007 Yaris Sedan
As an electronic technician. Red to me is always a power source like +12 volts not ground.
Old 06-10-2012, 06:48 PM   #7
Golddeenoh
Golddeenoh's Avatar
most of the electrical components, even the spark plugs need a ground to work. In theory making the ground on the car better will increase system responsiveness and improve ignition spark, it should also insure that at higher revs that the system electrical will not fail. I'm sure CTScott or Cali Yaris can give a more detailed description on the benefits but it is small unless you have done something drastic like an engine swap. I routed my wires differently than packetrace, I'll post a pick of it here in a few.
Old 06-10-2012, 06:54 PM   #8
packetrace
packetrace's Avatar
I am an electronic technician too...I know what you mean and it pisses me when someone use red for ground....but here it is only an esthetic reason....I hate the black wires in my engine bay thats why I went for red....
Old 06-10-2012, 06:54 PM   #9
packetrace
packetrace's Avatar
Yeah I am very curious to see....I will do the ECU ground...I had to do it but your reinforces my idea:D
what are your other ground ?
Old 06-10-2012, 07:05 PM   #10
Golddeenoh
Golddeenoh's Avatar
engine block, fender ground, ECU frame, Head lamp Ground, Throttle body,and CAI at its frame contact.
sorry for the dark photos it is rain here and I just ran outside and took these real quick for ya'll
Old 06-10-2012, 08:29 PM   #11
packetrace
packetrace's Avatar
interesting :) Ill definetely do the ECU one and the headlamp one...
Old 06-10-2012, 09:40 PM   #12
Golddeenoh
Golddeenoh's Avatar
"the heal lamp one was easy, the screw that went through the grounding screw sticks out of the other side so i just used those threads and a nut from the kit to put it on."
^ Bad idea Don't do that ground
Old 06-10-2012, 09:49 PM   #13
packetrace
packetrace's Avatar
goood idea
Old 06-12-2012, 08:18 PM   #14
Golddeenoh
Golddeenoh's Avatar
Exclamation WARNING!!!!!! Do not do this Ground.
DO NOT DO THIS GROUND!! Doing this ground will result in the car turning off when you either turn on the fog lights or attempt to turn on the head light/ high beams. The car will completely turn off, no electrical function at all, no signal lights, nothing. the engine will shut off. if this happens disconnect the extra ground(double ground) disconnect the negative, then reconnect the negative and the car will be fine.
Old 06-12-2012, 08:34 PM   #15
auxmike
auxmike's Avatar
I'm not doing any of this stuff. If this was such a great Idea I think Toyota would have sold it off the lot like that.... Just my .02.
Old 06-12-2012, 08:35 PM   #16
Everything on the chassis is a common ground. It sounds like you have something wired wrong with your lights, where you thought you were connected to bare metal as a ground there, but really are insulated to the ground with paint.
Old 06-12-2012, 09:24 PM   #17
Golddeenoh
Golddeenoh's Avatar
probably do with the lights as much trouble as i had installing the fog lights. it is the same grounding bolt as the head lights and fog lights. once i removed that ground I had no problems. the fog lights haven't been and issue until i put this ground kit on and then it wasn't until i used the lights that it went all funny business.
Old 06-13-2012, 08:36 AM   #18
packetrace
packetrace's Avatar
its just the hazard...
i had something like this..it was only the main ground pole who was not making contact with the negative of the battery....I grinded the NRG main pole....never had this problem since that...
it is not the headlight ground that caused that...the body is the ground...it cant cause that problem :)
grounding kit in 2012 haha55 DIY / Maintenance / Service 8 02-04-2013 10:54 PM
FS: OEM Toyota Vios Turbo Kit CTScott Items for Sale by private party 24 07-31-2011 09:12 AM
Grounding Kit EjDaPogi Middle East 43 03-30-2011 07:23 AM
Blending a Kit With a Factory Bezel sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 05-02-2010 11:54 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
