Old 06-19-2012, 03:59 AM   #1
YarYarBinks
YarYarBinks's Avatar
Drives: 07 Toyota Yaris LB
Send a message via AIM to YarYarBinks
Question I know this has been discussed but can I switch to synthetic at anytime
My car has 91000 and I want to make it last. I don't rack on miles like I did when I bought it. I think I did 30k + my first year. Anyways I read a few other posts but every time I read them they said the car was new, or they had some old ass car and ruined the seals after the switch. The yaris motor is a lot different than 90's cars. Just want to know if it's ok to switch. Thanks
YarYarBinks is offline   Reply With Quote
Old 06-19-2012, 09:35 AM   #2
boggydee
Drives: 2009 yaris 4dr hb
I made my switch on my 04 corolla with 100k! and no leak! and it seems to run and start smoother when i did the switch. I made my switch for my yaris at 40k and also no problem
boggydee is offline   Reply With Quote
Old 06-19-2012, 03:16 PM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The synthetic doesn't ruin the seals, the seal had gaps in them because they were old. Synthetic is less viscous than regular oil, and thus can leak out of these tiny holes that conventional oil usually can't.
Old 06-19-2012, 07:32 PM   #4
YarYarBinks
So should I make the switch or not? I want to get the most out of this car. Thanks for your input so far guys.
Old 06-19-2012, 09:17 PM   #5
Happy Little Pony
Drives: 2007 Yaris HB
http://www.mobiloil.com/USA-English/...ics/Myths.aspx
Mobil says it's OK. Why not try some Mobil1 High Mileage?
Happy Little Pony is offline   Reply With Quote
Old 06-19-2012, 09:33 PM   #6
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
with all these Free after rebate for Synthetic, why not? :)
The Beautification Of Car Enthusiast
Old 06-19-2012, 10:13 PM   #7
ViosFan
Shouldn't be a problem, I put synthetic in mine after 86k miles. And IMO, runs soo much smoother
ViosFan is offline   Reply With Quote
Old 06-19-2012, 11:50 PM   #8
Hershey
Won't hurt a thing . The synthetic does quiet the engine a bit .
Old 06-20-2012, 10:00 AM   #9
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
should'nt be a issue I've ran sythetic since new
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 06-25-2012, 09:40 AM   #10
YarYarBinks
So do you guys recommend a certain oil filter if I use mobile 1 synthetic?
Old 06-25-2012, 11:23 AM   #11
ViosFan
Mobil 1 has their own filters, I've heard good things about K&N, Purolators, Wix, Napa (Which I think is also made by Wix). Just use whatever you can find, except the cardboard crap.... (FRAM....)
Old 06-25-2012, 04:05 PM   #12
Qmobile
Qmobile's Avatar
i use a NAPA filter
Old 06-26-2012, 07:46 PM   #13
Happy Little Pony
Originally Posted by MickZEL View Post
I filled in my Yaris 07 Mobil1 Peak Life synthetic 5w50.
This oil is suitable for this motor?
What does Toyota recommend for the Yaris in Russia?
5w50 seems a little thick, especially when the weather turns cold. Here in the USA we use 5w30 or 5w20. The thicker oil shouldn't harm your engine, it will just lower your fuel economy.
Old 06-26-2012, 08:14 PM   #14
Happy Little Pony
If you aren't going to run a long oil change interval, any of the major brands would work. If I could only ever get one filter, I'd probably just buy a Bosch 3311. It's nearly identical to the Purolator Pure One without the yellow paint job. If I had to buy what they sold at Wal-Mart, I'd have no problem with the Fram Toughguard.
Old 06-27-2012, 05:42 AM   #15
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
walmart sells purolater for $3.50 i think :) i wouldn't recommend on very old car though, i used on 89 chevy van check engine came on after few hundred miles.. it has around 110k miles on it. but 100k on newer car should be fine
yaris4062007 is offline   Reply With Quote
Old 06-28-2012, 05:47 AM   #16
YarYarBinks
I was gonna do 10k intervals. I think I'll go with the bosch one. Is that a good pick?
Old 06-28-2012, 06:11 PM   #17
Happy Little Pony
If it's the Bosch Distance Plus filter, yes. That's the D3311 that comes in the plastic box. The regular Bosch 3311 filter would probably last that long, but for that many miles you'll want the best. This is the filter that I'm using right now.
http://www.boschautoparts.com/filter...ilFilters.aspx
Old 06-28-2012, 10:35 PM   #18
Chuck G
Drives: 2010 Yaris Sedan
Looks like that Bosch tested better than "brand B"!!!!!
The switch to synthetic Captain Slow DIY / Maintenance / Service 9 04-15-2012 01:02 AM
BJs Wholesale : SHELL conventional or synthetic $9 off a case ... Hershey DIY / Maintenance / Service 1 01-24-2012 11:42 PM
Can I switch to synthetic after my first 8000km oil change?? Moore General Yaris / Vitz Discussion 28 08-11-2007 12:29 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
