Old 06-19-2012, 04:32 PM   #1
cityboy
Drives: 2008 Yaris
humming noise
My 2008 Yaris has a strange humming noise randomly when come to a stop, it sounds like you pull steering wheel all the way to one side. I first thought A/C fan noise, but regardless A/C was on or not. Sound every loud. My car has 60K on it. Does anyone car have the same issue? thanks.
Cityboy
cityboy is offline   Reply With Quote
Old 06-19-2012, 04:44 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Manual or Auto tranny? I have you checked your fluids?
Old 06-13-2013, 03:48 PM   #3
rudeboy1
Drives: 08 yaris
Cityboy
My 08 Yaris hatchback with 80km does the same thing.
Had it at two Toyota dealers and they ruled out that it was not the water pump or alternator .
Just my luck it does not happen when they take it out for a quick test drive.
Mines not a standard ,it's an automatic.
Has anyone else had this problem?i would like to know what is doing it.
one mechanic said it may be the ABS sensor/ pump starting to go.
rudeboy1 is offline   Reply With Quote
Old 06-13-2013, 04:03 PM   #4
It may just be the electric power steering, particularly if the zero point calibration is off.
For the heck of it, try pulling the EPS fuse and driving to see if the sounds disappears. The wheel will be a bit hard to turn when not moving, but once you are rolling it will feel fairly normal.
Old 06-13-2013, 05:53 PM   #5
rudeboy1
Drives: 08 yaris
This happens when the steering wheel is not being moved at all and I am at or coming to a stop.Just as cityboy described
Old 06-13-2013, 06:21 PM   #6
That's why I say the zero point calibration for the EPS may be off.
Old 06-22-2013, 01:50 PM   #7
racerb
I've had a humming noise in every car I've owned over the last 15-20 years, mine goes away when I leave the Wife at home, give that a try!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 08-31-2013, 04:46 PM   #8
nookandcrannycar
racerb
humming noise
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
humming noise greg86m DIY / Maintenance / Service 6 04-14-2012 10:15 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Humming noise when turning the steering wheel!! Help?? mhkritzinger DIY / Maintenance / Service 7 09-28-2009 08:27 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
