Old 06-20-2012, 12:58 PM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Dealer wants my Cruise
Dealer (Spinelli Montreal)just called me up and said they'd pay me $460 to take out my Cruise control as evidently it interferes with police and fire radio communications. Well as i may have used the device once or twice since buying the car new in 08 i'm thinking they can have it.
Any one else get this notification?
Have Yaris will travel..
Old 06-20-2012, 01:14 PM   #2
Nice! Take the $460, let them pull the Rostra kit, and install the OEM stalk per my DIY, and you'll still be up $400.
Old 06-20-2012, 01:44 PM   #3
bronsin
bronsin's Avatar
Weird.
How is that even possible. There arent any transmitters involved. (are there?)
He must want to install it on his mistresses Yaris.
Old 06-20-2012, 01:52 PM   #4
Weird.
It is just the opposite. Supposedly the Rostra has some issues where it is susceptible to radio frequency emissions and can malfunction if a high wattage transmitter is keyed in close proximity.
Old 06-20-2012, 02:00 PM   #5
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I am an Amateur Radio Operator (Ham Radio Operator) and as such I have a radio in my Yaris. I have done extensive testing to get the cruise control to malfunction. I have the same cruise control as the OP has described (aftermarket Rostra one).
The only way I was able to make the cruise contol malfunction was to take a handheld radio and plug it into the cigarette lighter outlet. Otherwise using different frequencies and power levels I was unable to make the cruise control malfunction.
I tried using a normal VHF/UHF transmitter with power up to 50 watts and have experienced no problems with the cruise. But .. using 5 watts (and plugged into the cigarette lighter outlet) I was able to make it malfunction. So .. an increase of power does not have an effect on the unit.
I have also been asked to remove my cruise control by the dealer .. and I have refused to remove it. I was offered $487 to have them remove it.
edmscan is offline   Reply With Quote
Old 06-20-2012, 02:29 PM   #6
jambo101
jambo101's Avatar
If i used it frequently i'd certainly be keeping it but i might be in a position to use it once a year if that so by all means have the darn thing which i never wanted to begin with but it was part of the power option package that came with the car, you want air? then you gotta have power windows and cruise control
Old 06-20-2012, 02:43 PM   #7
bronsin
bronsin's Avatar
Oh I thought it was factory cc.
Learn something every day!
Old 06-20-2012, 02:45 PM   #8
edmscan
edmscan's Avatar
Mine was dealer installed ... not a factory install.
Old 06-20-2012, 02:56 PM   #9
The recall is only for the dealer/port installed Rostra aftermarket stand-alone system, not for the OEM cruise, which is built into the ECM.
Old 06-20-2012, 04:07 PM   #10
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
So, as you've all pointed out, I have the Rostra kit as well, which was there when I bought it. I'd love to jump on this "recall"...should I contact the lot that I got it used from to see if they know anything about it?
Old 06-20-2012, 04:25 PM   #11
To the best of my knowledge, so far the recall is only for Canada.
Old 06-20-2012, 04:27 PM   #12
suckerface
#1 Lemming
suckerface's Avatar
Bollocks.
Old 06-20-2012, 05:06 PM   #13
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Do what CT says, and get them to remove it, and then do the OEM one!
Old 06-20-2012, 06:00 PM   #14
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup...sell it!
Old 06-20-2012, 07:36 PM   #15
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Well we've got a rostra dealer installed kit, and it cancels speed selection when we hit a bump in the roads....no idea why.....first module was replaced because it shut off intermittently and wouldn't turn back on.....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 06-21-2012, 06:25 AM   #16
bronsin
bronsin's Avatar
Well well now I have to add Rosta CC to the list of things to NEVER do to your vehicle like wash the engine with a hose and degreaser and theft alarms.
Unless you are a sucker for punishment in which case by all means go right ahead!
Old 06-28-2012, 04:15 AM   #17
jambo101
jambo101's Avatar
Everything went smoothly,i now have no cruise and am waiting for a $460 check from Toyota Canada
Old 06-28-2012, 09:42 AM   #18
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
they just ask me that a week ago when i was getting my ac checked..i said i dont use cb radio...lol
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
Someone Please Help With SET & Local Dealer Nightmare! sanityassassinv2 General Yaris / Vitz Discussion 32 11-26-2008 11:32 AM
Dealer Adding Cruise On 07 LB WMERCERECU77 General Yaris / Vitz Discussion 7 08-24-2007 01:38 PM
