Old 07-06-2012, 08:37 AM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Looking to lower it.
I have a 2007 LB. I am looking to lower it. It has 74 thousand KM on the clock.Stock suspension seems ok, however it's high up the ground. Time to drop it low. It's daily driver.I have on 15 x 6.5 rims.
Any suggestions?
Old 07-06-2012, 08:57 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
With that size wheel, you can do almost anything to it to drop it. Cheapest option would probably be Tanabe NF210s. However, Tanabe springs do not last very long - they rust easily.
Or you can get some springs from Garm at Micro Image. He has some decently aggresive ones for under 200 I believe. HE has them made to order.
Old 07-06-2012, 09:14 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
springs or coilovers depending how low you want. If you want springs, once my megan coilovers are on I will be selling my ksport springs.
Old 07-06-2012, 09:17 AM   #4
junorico24
junorico24's Avatar
I haven't decided yet.It's a daily driver. Bro give me the pros and cons on both.
Old 07-06-2012, 09:38 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
shocks and springs are cheaper, but non adjustable. Coil overs are adjustable, all for height, and some for damper as well.
I have Megan Racing coilovers I bought from Micro Image, and I love them. It rides so much better than stock, and the only time you really know it is stiffer is larger bumps on the highway.
Some coilovers are less stiff, other are more so. Same for shocks. It really depends on what type of ride you are looking for.
Colin Chapman disciple
Old 07-06-2012, 09:41 AM   #6
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
coilovers = adjustable, a lot lower, expensive
springs = not adjustable, around 1"-2" of drop, relatively cheap.
springs...($150-$225)
http://shop.microimageonline.com/Springs_c19.htm
coilovers...($860-$1900)
http://shop.microimageonline.com/Coilovers_c20.htm
most guys around here go with micro image. I have had good luck with them. I have bought quite a few items from them and have always been happy. I actually run the H+R springs with a mild drop of about an inch. I was going for handling.
Old 07-06-2012, 01:45 PM   #7
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Here's my experience:
I had Megan Racing coilovers and found them way too stiff for daily driving, even when adjusted to full soft. Plus, the paint on my springs peeled off after 13 months and the springs started to rust.
I currently have Tokico HP shocks/struts and Tein S-tech springs. It's a much more comfortable street setup, but the handling is still very good. In fact, I'd argue it's a better setup for those who primarily drive their Yaris on the street. It feels more connected to the road and isn't as easily upset by imperfections in the pavement. I like it very much.
If I were to do coilovers again, I'd go with the Tein setup. Although it does not have adjustable damping, I rarely used it on the Megan Racing units.
Old 07-06-2012, 01:59 PM   #8
1.5
Form>Function
1.5's Avatar
Im waiting on some megans... hope they dont break my back
Old 07-06-2012, 03:02 PM   #9
i had megan coilovers, too. very firm for a daily driver
ive also used eibach prokits, i currently have eibach sportlines. ive also been in a couple yarii with megan springs....much more comfortable
ive been in crandalls yaris with tein basic coilovers and found them too soft....i have h-tech on my vibe and they are oem comfy, but oem soft
i love my progressive rate eibachs....id run tokico's and eibachs....i never really mess with the height once its set
Old 07-06-2012, 03:22 PM   #10
junorico24
junorico24's Avatar
SOLD!
Tukicos and Eibach springs package it is. How much drop do we get from this set up?
Old 07-06-2012, 04:00 PM   #11
Prokits are 1"
Sportlines are about 1.7"
Old 07-06-2012, 05:33 PM   #12
junorico24
junorico24's Avatar
Thanks, homies!!
Old 07-06-2012, 05:34 PM   #13
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
I got Eibach Lowering springs, specially for the XP9. 2,5cm drop all around... It's not ''that'' noticable from the outside, but if you put some wheelspacers on ur rims you'll definatly see it has been lowered. Also the ride is amazing! Cornering is doable even with over 100km/h.
G-Ammo is offline   Reply With Quote
Old 07-06-2012, 07:27 PM   #14
Ya, 2.5cm = 1" ...
Prokits + 205/55/15 tires (dolls the fenders more)
Old 07-06-2012, 10:53 PM   #15
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I put in a set of Tokico Blues and Tien s-techs about 2 weeks ago and I'm pretty satisfied with them. It's a 2" drop, but I'm also running small on my tires (205/50R15) so things like a trip through a carwash is right out. Combined with a TRD rear sway bar, it now corners almost dead flat, and even stresses the sidewalls of the tires.
Old 07-10-2012, 09:08 PM   #16
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
tokico blues an tein stechs ftw!
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 07-13-2012, 02:36 AM   #17
ruvios
Drives: 2012 1.3G AT
hey guys. what about wheels on 205/40/17? what is the best thing for this kind of tire?
planning to get Tein S-Tech with a 1.5 drop. what do you think? need a 1 to a tight 1 finger gap.
thanks.
ruvios is offline   Reply With Quote
Old 07-14-2012, 07:03 PM   #18
nimuntak
Nikki Alanna
Drives: 08 Meteorite Metallic Hatch
I'm selling Tein coil overs from my Yaris, $1100.
Text me if you're interested (587) 894-2501
nimuntak is offline   Reply With Quote
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Want to lower 1" or so. hmmm piranha0522 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-25-2011 03:59 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
