Old 08-09-2012, 12:38 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Is there anyway to fix this?
caineroad is offline   Reply With Quote
Old 08-09-2012, 02:28 PM   #2
ajmarshall169
ajmarshall169's Avatar
Drives: 2007 toyota yaris sports
sand it down and paint over it. same thing happen to my old car.
ajmarshall169 is offline   Reply With Quote
Old 08-09-2012, 02:31 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
you could repaint it or just replace the whole thing.
right below the section in question, there s a small plastic insert that is covering the nut which holds it to the stud. just remove the plastic insert and take the nut off. the wiper comes right off. the wiper is ribbed (there is a propper word for it but it eludes me) so that it will turn with the movement of it.
I actually used the dirt on my windshield for alignment when I removed mine. I had to remove my cowl for spring removal.
good luck regardless of what you decide to do.
Old 08-09-2012, 04:42 PM   #4
I was lucky enough to obtain a new set of pristine arms at a wrecking yard a few years back. I use my old corroded ones in the winter, and switch to the second good set in the summer.
Old 08-09-2012, 07:06 PM   #5
Lux
Lux's Avatar
Drives: NCP91
Corrosion on the surface could mean corrosion on the splines beneath it which attach the arms to the motor. Don't bother playing doctor dress-up and just replace the arm altogether.
Splined
Old 08-09-2012, 07:51 PM   #6
BEEF
BEEF's Avatar
splined, there we go. was a bit brain dead earlier today. it happens.
Old 08-09-2012, 08:31 PM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
^brain was thinking "condoms".
Old 08-09-2012, 08:46 PM   #8
bronsin
bronsin's Avatar
How did that happen?
Personally I dont worry about things like that unless I have nothing better to do someday.
Old 08-09-2012, 09:44 PM   #9
WTF are you talking about!? I have never seen spline corrosion on any wiper arm that exhibits this common problem of paint blistering on this part of the arm.
Old 08-09-2012, 10:10 PM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Based on the location of the blistering, it's not from the spline. The spline is under the cap, all the way on the right of the arm. This looks like a flaw in the finish around the pivot pin, possibly caused by mechanical damage (ice scraper, "snapping" them down too hard, rock chip, etc.) I'd say just get a new/salvaged one.
Hey everyone...Did anyone get a FIX for the Oversteer Problem at fwy Speeds under war jay cobbs General Yaris / Vitz Discussion 0 06-13-2012 10:10 AM
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
LED Indicator Fast Flash Plug and Play FIX 1NZYaris1 In Car Entertainment + Electronics (audio / video / alarm) 5 04-18-2011 03:47 AM
Uh oh: How Much To Fix This? bronsin General Yaris / Vitz Discussion 11 12-05-2009 07:25 PM
firts mecanic fix! the_boss Off-topic / Other Cars / Everything else Discussions 1 08-21-2009 03:56 AM
