Old 03-01-2007, 07:50 PM   #1
redyaris
Shiny Chromey Coolness
redyaris's Avatar
15 x 6 or 15 x 6.5???
Fellow Yarisers:
I know all the experts can advise me as I am dumb stupid on this stuff...I want to replace the steel 15 inchers on my liftback with aluminum...I have been drooling looking at Violins Konigs and HTM Yaris SSC's...
I want to keep the same 185 60 15 Bridgestones I have on now. I dont want to increase wheel size. Number one, im cheap and dont want to spend a ton on rims.
Number two, Im scared of ruining the great ride of my liftback. I had custom wheels on my Volvo turbo and they made my car vibrate at speed. I dont want that again...
Question is: I see a lot of wheel sizes of 15 x 6.5. Will the 185's fit this wheel? or do I get 15 x 6???
Thanks!
Old 03-01-2007, 09:16 PM   #2
OK Yaris
Drives: 2007 Liftback
Stock Bridgestones fit the Heliums just fine. I feel the handling improved because the tire sidewall appears more vertical, and it seems more of the tread is planted solidly on the road. The car feels more stable in curves. Absolutely no change to stock ride quality.
OK Yaris is offline   Reply With Quote
Old 03-01-2007, 09:26 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
personall I prefer the 15x7's
but if you are going to keep your stock tires on the new wheel go with 15x6, 15x6.5 has too much of a streched look for me.
Also if your car vibrates after you wheels have been changed it is most likely because they were not properly balanced, most newer wheels can only have weight on the inside. Most tire guys are too lazy to use the sticky weights are ment for that style wheel and just use hammer weights on the back lip... so when you get your new wheels on make sure you tell the guy at the counter you want a DINAMIC balance with sticky weights, and for not reason should they STATIC balance them... static balancing is the lazy way that makes car vibrate
Hope that helps
Old 03-01-2007, 11:09 PM   #4
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Hope that helps
What the different with Dinamic balance and Static Balance? I got my wheels and tires done at Kauffman Tire, but everytime i hit 80 and up it's kindda vibarate is it got anything to do with Balance and rotate?
Old 03-02-2007, 12:44 AM   #5
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Tirerack specs for the OEM Potenza RE92 says the rim width range is 5"-6.5".
Heres the link- http://www.tirerack.com/tires/Spec.j...%3D86TR5RE92V2
Old 03-02-2007, 01:09 AM   #6
Typer73
Tired of the Stars!
Typer73's Avatar
Drives: '07 Meteorite LB
Static Balance
Also known as "bubble balancing" uses a fairly inexpensive machine to balance the wheel/tire assembly at rest using a bubble level as an indicator. This technique takes some operator skill to perform good balancing as you need to carefully split the balancing weights on the inside and outside of the wheel to avoid dynamic imbalance.
Dynamic Balance
Also known as "spin balancing" can be done either on or off the vehicle. The majority of tires are probably balanced on computerized spin balancers. After clamping the wheel on the machine, setting the wheel dimensions, it spins up and calculates the locations and amount of weight to apply to the rim to correct the balance. Most spin balancers center the wheel on a cone-shaped mounting device. This works fine for vehicles that locate the wheel on the vehicle via the hub (i.e. "hub-centric"). For vehicles, like Toyota, that locate the wheel on the hub via the lug nuts (i.e. "lug-centric") a special lug-centric adapter should be used to properly balance the wheel. On vehicle balancers avoid this problem, spinning up the wheel in place.
We've always insisted on dynamic balancing, high speed, so we won't get the vibrations on the highway.
Typer73 is offline   Reply With Quote
Old 03-02-2007, 09:15 AM   #7
jamal1984
Originally Posted by Typer73 View Post
Static Balance
Dynamic Balance
Thanks
Old 03-02-2007, 11:02 AM   #8
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by redyaris View Post
Fellow Yarisers:
Thanks!
You can fit the 185's on a 6 or a 6.5 wheel. Good advise, look for lightweight rims. Heliums are the best price/weight deal. You can get them really ship from supporting vendors.
Also when you are done with your current tires you can upgrade to a 195/55/15 that will be a perfect fit for the rims, will improve handling and you wont sacrifice your confy ride!
Old 03-02-2007, 06:29 PM   #9
OK Yaris
Exactly what I have in mind. With 11,000 miles in 6 months so far, it won't be long before I'll be doing that!
As I've mentioned in another post or two, don't be cheap when it comes to the mounting and balancing. Find a shop that mounts aftermarket wheels all day long. If you carry wheels into a shop for mounting, don't be surprised if they charge a little extra since you didn't buy the wheels from them. Mike
Old 03-02-2007, 11:14 PM   #10
redyaris
redyaris's Avatar
Thanks guys! Appreciate the tips.
Old 03-03-2007, 03:24 PM   #11
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Hey Red , I will post some pics of my new Konig Feathers in gold later today . Make sure you have a napkin to wipe up the drool :)
Old 03-03-2007, 06:43 PM   #12
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Here ya go :) My GF said the Red Yaris would look "HOT" with the gold wheels . These are 15x6.5 BTW with 195/55 not 50's as I posted earlier . These wheels are $380 shipped to SC from Cali .
Old 03-03-2007, 07:32 PM   #13
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
When talking Static vs Dynamic ANYTHING . Static is always "still" , dynamic is "in motion" . For example When refering to a static xray , the xray was taken in one shot to produce a still image . When refering to a dynamic xray , it is a series of xrays (30 frames per second or more ) to produce a range of motion that is visible . Dynamic xray is also called fluoroscopy .
Yeah , I'm bored :)
Old 03-04-2007, 12:42 AM   #14
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Man those look sick! I wish the came in bronze!! I'm stuck with stupid Heliums.
Old 03-04-2007, 11:53 AM   #15
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
I will be glad to ease your pain. Feel free to give them to me.
jdubau55 is offline   Reply With Quote
Old 03-05-2007, 10:50 AM   #16
redyaris
redyaris's Avatar
Stupid Heliums LOL...I would kill to have a set of them!!!! I think im going silver in any wheel however. Dont want to get ricey wid it!
Old 03-06-2007, 12:35 PM   #17
CASTREX
CASTREX's Avatar
This looks ricey to you???
Bronze heliums on a Bayou blue sedan
Old 03-06-2007, 12:46 PM   #18
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
NOPE.. looks good to me.
Go4th is offline   Reply With Quote
DIY 07 Sedan Rear Speaker install vodkalush DIY / Maintenance / Service 32 10-20-2017 03:40 PM
stock 07 hb wheels width? 6 or 6.5? Ric n Sov's Vitz RS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-18-2007 10:45 PM
upgrading the factory sounds acrbill In Car Entertainment + Electronics (audio / video / alarm) 3 12-22-2006 03:33 PM
Work Wheels BulletProofAuto Sponsors Classifieds Area 1 10-19-2006 06:46 PM
