Old 08-26-2012, 02:24 AM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
projector hid bulb replacement.
I have the micro image projector headlights, and now only one works. The dead light started flickering yesterday, and wouldn't work today. Where can I get a replacement hid bulb?
marlondog is offline   Reply With Quote
Old 08-26-2012, 02:59 PM   #2
Swap your ballasts side to side to make sure its a bulb or ballast issue. If the problem follows the ballast, you know you need a new ballast.
Garm can like source a replacement bulb for you, if that's the issue, as the projectors use special bulbs
Old 08-26-2012, 03:37 PM   #3
The bulbs are D2H bulbs and can be purchased on the retrofit source.
Old 08-26-2012, 03:38 PM   #4
http://www.theretrofitsource.com/pro...oducts_id=4126
Old 08-26-2012, 03:39 PM   #5
I would also suggest 5000k or 4300k.
Old 08-26-2012, 04:34 PM   #6
Pur_Blu
Pur_Blu's Avatar
Drives: NCVC craziest
Send a message via AIM to Pur_Blu Send a message via Yahoo to Pur_Blu
Umm Ebay they go for like 15 a pair for bulbs and if u need a replacement ballast hit up Garm for a free swap or Ebay for like 50.
I've ran my 8k hid's for over a year with no problems.
http://www.yarisworld.com/forums/image.php?type=sigpic&userid=5122&dateline=1314464  468
Pur_Blu is offline   Reply With Quote
Old 08-27-2012, 07:47 AM   #7
marlondog
marlondog's Avatar
Thanks guys. I removed the headlights, and checked to see if it was a problem with the ballast. So I plugged the lights into the other lights' ballast, and the light still wouldn't work. Now the halo lights don't want to work. I've checked the wiring, and made sure everything is plugged in correctly, but still no halo lights.
Old 08-27-2012, 04:03 PM   #8
I know one of my halos sometimes becomes dim. Check all the connections again? I've taken the projectors apart, and I know that the LED wires aren't exactly soldered on very well.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Replacing headlight bulbs nsmitchell DIY / Maintenance / Service 47 02-14-2016 09:07 PM
replacement bulb question justinparadise21 Cosmetic Modifications (Exterior/Interior) 2 11-06-2008 01:52 AM
Exterior LED bulb Replacement & Tint ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 2 04-27-2007 05:45 PM
