Old 08-27-2012, 09:47 AM   #1
david_827
Drives: 07 Yaris Sedan
Power Windows Question
Hello All,
didnt know exactly where to post this. As those with power windows know, the driver's window comes with the "auto" down option when you push the switch all the way down. My question is, can this capability be expanded to the other windows?
david_827 is offline   Reply With Quote
Old 08-27-2012, 12:10 PM   #2
ajmarshall169
ajmarshall169's Avatar
Drives: 2007 toyota yaris sports
you would have to switch out the switches with the one like the driver door. the driver door is a double switch. the other ones are single switchs
ajmarshall169 is offline   Reply With Quote
Old 08-27-2012, 03:05 PM   #3
david_827
Thanks, do you know if this would be something easy? Is there alot of wiring involved with swapping switches?
Old 08-27-2012, 03:38 PM   #4
The easiest way to do it is to use one (2 dr) or two (4 dr) DEI 530T modules. Here is a thread with a DIY that I put together for wiring them:
http://www.yarisworld.com/forums/showthread.php?t=31473
Old 08-27-2012, 03:58 PM   #5
david_827
Thanks CT!
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Power Windows Leg Room nwdixieboy General Yaris / Vitz Discussion 9 04-06-2006 07:19 AM
