Old 09-21-2012, 06:46 PM   #1
Deshi Basara
Drives: 09 Yaris Hatchback
Tachometer HELP!!!
I saw the DIY topic already but I did not know that tachometers come in very short wires. I was wondering where am I able to buy the wires to extend the length of it to reach the proper wiring place. I was shock when I saw that the wire is only 15 inch long. Please help!!!
Deshi Basara is offline   Reply With Quote
Old 09-21-2012, 08:05 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
radio shack is probably fine or you can get some at an autoparts store too.
it really doesn't matter what wires you use. You may want to use the same colors as to not get confused. I would recommend soldering them and using heat shrink. that gives the best connection and the best protection from shorting out.
it isn't pulling that much current so size shouldn't be an issue. just don't use 30 gauge or something the size of a human hair. 22 gauge and up should be fine.
(just my 2 cents)
Old 09-21-2012, 08:22 PM   #3
Deshi Basara
I called Autozone and they didn't even have anything at all...lol
How much does soldering or heat sink thingy cost??? It's my first time installing a tach because I got tired of listening to the damn engine sound
Old 09-21-2012, 10:43 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If you don't know how to solder, you can go this route. Strip and crimp. Good luck.
Yaris 2000 - tachometer stop display rpm holoais General Yaris / Vitz Discussion 2 07-25-2011 08:43 AM
Tachometer 09BoostedVitz Performance Modifications 12 07-21-2011 09:48 PM
keyless entry with tachometer matash In Car Entertainment + Electronics (audio / video / alarm) 12 01-29-2010 03:36 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
