Old 09-23-2012, 10:58 AM   #1
ReidReid
Drives: 07 3 door auto
Remove/Re-Assemble Map Light Fixture
I have a 2007 3 Door and I unknowingly disassembled and removed the little sockets that hold in the map lights. It appears that the only way to re-install the light sockets is to access the top of the map light fixture that is attached to the headliner. Does anybody know a simple trick to remove this fixture? I have attached a photo of the piece I'm talking about in case I used the wrong terminology.
Thank you!
Reid
ReidReid is offline   Reply With Quote
Old 09-23-2012, 11:56 AM   #2
It is held up there with a couple of spring clips, so you simply pull it away from the headliner.
Old 09-23-2012, 12:55 PM   #3
ReidReid
Thanks! So I simply pull it straight down without squeezing any tabs or anything? It pops straight out if you pull it hard enough?
Old 09-23-2012, 12:56 PM   #4
Yes. just get a finger or two between the edge of it and the headliner and then pull it down.
Old 09-23-2012, 01:27 PM   #5
ReidReid
Thanks that worked perfectly. I found the four spring clips by poking around with a flat plastic thing.
Old 09-23-2012, 03:36 PM   #6
It takes an aggressive tug, doesn't it?
Old 02-22-2013, 06:30 PM   #7
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Just pulled this down. Super easy if you just us a flathead to depress the clips 1 at a time. Now to figure out the rest of the headliner.......
Old 09-08-2014, 06:06 PM   #8
Lenore
Vehicular Hobbiest
Drives: '07 Yaris, 4dr, 1.5L, auto
Thank you so much for the photographs and the followup. :-) That helped me out immensely.
Lenore is offline   Reply With Quote
Old 09-09-2014, 05:39 AM   #9
willieG
Drives: 09 hb 2nzfe m
excellent. ta.
willieG is offline   Reply With Quote
Old 09-09-2014, 11:32 AM   #10
axiom
axiom's Avatar
Drives: 2007 Yaris
I've been wondering, anyone know what those three little vent looking things at the top in the first pic are for?
axiom is offline   Reply With Quote
Old 09-09-2014, 11:50 AM   #11
My guess is either for the temperature monitor on those that have autoclimate controls, or the mic for the bluetooth.
I am waiting to have some free time on hand and hack it so i can install my mic behind this.
Old 09-09-2014, 03:32 PM   #12
jcboy
Drives: Sedan 07
never thought of bluetooth mic, but my guess is for cabin temperature sensor as Euro yarises do get autoclimate control, though the bluetooth mic makes sense.
i hacked into it and put an LED there that lights up with my park lights (at night).
Map Light Removal Geology DIY / Maintenance / Service 6 03-16-2011 06:32 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Map light question Qilene15 Cosmetic Modifications (Exterior/Interior) 7 04-21-2010 09:30 AM
MAP LIGHT drell42 Cosmetic Modifications (Exterior/Interior) 2 05-21-2007 07:30 PM
