Old 10-12-2012, 12:27 AM   #1
Jamus
Drives: '12 3dr Yaris L
AC panel removal?
It's starting to get cold and I'm looking to undo the AC from the defrost setting. My problem is getting it all loose. I just have a fear of breaking something. Here's a pic if needed. I need to get behind the dial circled in red and assume I just pry off the whole panel outlines in yellow. Thanks for any help.
Jamus is offline   Reply With Quote
Old 10-12-2012, 01:27 PM   #2
etherdude
Drives: 2012 Yaris SE 5-speed
Why? You don't need to.
The compressor does not kick in for defrost unless you push the A/C button (on the right) while using defrost. Thus you should not need to disconnect anything.
Doug
etherdude is offline   Reply With Quote
Old 10-12-2012, 03:59 PM   #3
The AC EWD for the 2012 shows that it has the same linking of the defogging position of the first knob to the output of the AC switch on the third knob. It looks like you can simply disconnect the light green wire in pin 1 of the first knob connector to unlink it (as opposed to having to pull the knob apart, like what had to be done on the 2nd gen).
As for removing the control panel, the service manual doesn't show and fasteners, so it does appear to just pull off.
Old 10-12-2012, 08:58 PM   #4
DanMC
Drives: 2012 Toyota Yaris
CTScott, can you please tell me where i can purchase a service manual that covers 2012 Yaris ?!...Thank you .
Dan
DanMC is offline   Reply With Quote
Old 10-12-2012, 10:36 PM   #5
Dan
You can probably purchase a paper version from you local dealer for a wheelbarrow load of money, or you can subscribe to techinfo.toyota.com for temporary access.
Old 10-13-2012, 09:24 AM   #6
GTBaker
GTBaker's Avatar
Drives: 2012 Yaris LE
Doug
Ya why? I always use my AC in the winter in conjunction with heat the re-circulation button to clear the car of excess humidity.
GTBaker is offline   Reply With Quote
DIY rear Interior panel removal 09 3dr LB bkndacn Cosmetic Modifications (Exterior/Interior) 10 03-11-2013 01:05 AM
Is Door Panel Removal need for tinting? fatlard Cosmetic Modifications (Exterior/Interior) 4 03-26-2011 12:28 AM
Yaris 1.0L GS 2000 Driver's Door Panel Removal milooshea DIY / Maintenance / Service 3 01-30-2011 12:20 PM
Back door panel removal ('00 Vitz) HELP ! Demon DIY / Maintenance / Service 2 09-27-2010 08:42 PM
