Old 10-16-2012, 07:52 PM   #1
corman007
Drives: 2003 Yaris terra 5 dr
Parking/ side lights come on when brake pedal is depressed
Hi all,
I just had a rear wheel bearing replaced and now find that when i depress the brake pedal the side lights come on and the display in the car dims, i don't know how replacing a bearing would affect this (i know the abs is built into the bearing somehow) any ideas much appreciated.
Regards james.
corman007 is offline   Reply With Quote
Old 10-16-2012, 07:53 PM   #2
corman007
sorry its a 2003 yaris terra 5 dr model - european
Old 10-16-2012, 08:31 PM   #3
Sounds like they pinched a wire or two in the process of working on the car and bridged the stop light wiring with the turn signal wiring. I would start with following the wires from tail lights as far as you can and inspect them for damage.
Old 10-17-2012, 01:50 PM   #4
Geoff Peace
Drives: Yaris 1.33 litre 2011
Agree fully with the above. Also check the earth connections for the rear lights. I cannot think why they would be disconnected or damaged during replacing a wheel bearing but if the connection is poor or non existant the power will try to find a route to earth through other bulbs.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Why would my tail lights work but not my brake lights? rickyml Middle East 11 10-06-2010 10:27 AM
side marker lights yrsdrgn Cosmetic Modifications (Exterior/Interior) 154 07-10-2009 02:55 PM
Side Marker Lights Stoln General Yaris / Vitz Discussion 1 07-04-2007 02:44 PM
Fog Lights - only right hand side JayCee Cosmetic Modifications (Exterior/Interior) 3 09-26-2006 05:44 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
