Old 10-20-2012, 08:47 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Transmission..once again
Not sure if anyone has seen my previous posts about my transmission issues but I still have not found a cure. My problem is my Yaris feels as though I am pushing it to its limit when driving, shifts at different intervals, and feels rough when shifting. I have had the transmission fluid changed and have had it in to Toyota but they claim there's nothing wrong with it. Is there something that can be looked at to see if its working properly?
Twistoffate0817 is offline   Reply With Quote
Old 10-20-2012, 08:55 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
You might want to consider recording the sounds coming from the tranny. I did that and the mechanic was able to spot the problem in my case (gearbox).
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
need experts helo on robotic transmission clutch mariann DIY / Maintenance / Service 0 10-03-2012 12:51 PM
Transmission & Reverse Twistoffate0817 DIY / Maintenance / Service 4 08-28-2012 06:50 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 07:35 PM
