Old 11-17-2012, 02:36 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Got my coilovers today, what's up with Megans rear spring perches?
Hey all,
if you look at the bottom of the spring perches on the tein coilovers there is a nut that secures the rear spring perches to the beam, on the megans there is no such way to secure it, is it just supposed to sit in the beam, that's it? Does it rely on spring preload to keep the spring in the car? Looks a little sketchy
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 11-17-2012, 02:39 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Yes sir it just sits there. Just like the stock springs just sit straight on the perches. The weight of the car will keep them in place.
Old 11-17-2012, 02:45 PM   #3
DeathBeard
DeathBeard's Avatar
Ok cool so no worries about the spring becoming unseated I was hoping either you or mr. miles would see it
Proverbs 16:9
Old 11-17-2012, 02:46 PM   #4
DeathBeard
DeathBeard's Avatar
pic
Proverbs 16:9
Old 11-17-2012, 03:07 PM   #5
1.5
Form>Function
1.5's Avatar
looks so nice and clean just flip it for install lol
after you're done installing, if you still want shorter stiffer springs lmk first. I have the 170mm/7kg that I don't really need anymore since I am picking up a few shorter ones.
Old 11-17-2012, 04:23 PM   #6
DeathBeard
DeathBeard's Avatar
thanks brother Once again thanks Garm for the excellent service!
Proverbs 16:9
Old 11-18-2012, 12:08 AM   #7
yariseggvvti
Drives: Yaris Hatchieback
Deathbeard: How did you set it up. Do you do the setting before you install or install it and then adjust it. Thanks!
yariseggvvti is offline   Reply With Quote
Old 11-18-2012, 01:20 AM   #8
mr_miles
Drives: 2013 Yaris
If you go without the perches, I suggest investing in some thick cable ties. I use very large ones on the bottom of the springs to hold them in the perches( two on each spring). Fortunately, there are holes in the bottom of the perch, and the ties work perfect there.
Old 11-18-2012, 01:54 AM   #9
welcome - enjoy - PICS PICS PICS
Old 11-18-2012, 04:55 AM   #10
1.5
Form>Function
1.5's Avatar
If you are going for perfect fitment, then you may never finish making adjustments lol. I still make fine tuning adjustments almost weekly. Its like you are always chasing that perfect setting. If you are using them for a moderate drop and performance then I would set them, install them and let them settle, and then make your final adjustments.
If using the standard 190/3 springs you don't need the zipties as much. The soft rate allows the chassis to hold the spring in place. For stiffer springs absolutely I would zip tie them but I've only ever done so on top. The bottom is so tight it like locks in place.
Old 11-18-2012, 06:35 AM   #11
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
1.5 is right, the weight of the car and the shocks prevent the spring from coming out.
-Derrick-
CRUD, someone dented my rear door today Yawesh General Yaris / Vitz Discussion 11 03-25-2019 08:24 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 08:24 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
