Old 11-22-2012, 10:42 AM   #1
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Does E-Zpass go in Window or License Plate
Happy Thanksgiving everyone!
Does anyone know if the E-Zpass goes in the window or on the License Plate?
Received two new ones last week and don't know if the Window Antenna interferes with it or not.
The Toyota Yaris isn't on E-Zpasses website as a car that does interfere.
Want to make sure so I'm not going back and forth with them to get the right one.
Thank you all.
screenprintr is offline   Reply With Quote
Old 11-22-2012, 10:51 AM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
i stick mine right inside the driver's side upper glove box and havent had an issue for the past few years. Usually you stick the e-z pass right under the rear view mirror on your windshield.
Old 11-22-2012, 11:01 AM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Thank you all.
Don't have an EZPass, but I'd think that it could/would go in the front window.
The window antenna (on the sedan only) is in the back window, and I'm 99.9% sure that you'd stick the EZPass on the front window.
edit: Yeah, what enviri, said. You should be good to go.
Old 11-22-2012, 12:32 PM   #4
sex
sex's Avatar
Drives: 09 5DR
The white boxy ones go on the windshield. The black bar ones go on the plate
Old 11-23-2012, 01:35 PM   #5
narly charley
Drives: 2010 Yaris "L" 5 Speed
Yes, white box goes on the top of the windshield. If you don't put it in the right area, they will charge you. At least that's what they do in my area.
narly charley is offline   Reply With Quote
Old 11-27-2012, 08:43 PM   #6
screenprintr
I know where the White box and Black bars go.
I'm asking if the Front Windshield Antenna interferes with it or if you know the correct one for the 2010 Yaris Sedan. Someone posted a picture/drawing, but that's a hatchback not a sedan.
The back window has a Defroster. I don't think it's both the Defroster and Antenna, but I could be wrong.
I checked the EZ Pass website and they don't list the Yaris so I'll go with that.
Old 11-27-2012, 08:48 PM   #7
The defroster and antenna are both on the back on the sedan. If you look closely you will see that the lines are in two sections. The EZpass will work fine on the windshield. I have one on each of my Yaris.
LED License Plate Frame chrisj Cosmetic Modifications (Exterior/Interior) 7 09-22-2010 11:21 AM
LED License plate frame, Need help! bandulete General Yaris / Vitz Discussion 7 12-17-2009 05:44 PM
WTB: Front License Plate Mount and OEM wheels/tires Snarf77 Willing to Buy by private party 3 07-23-2009 12:43 PM
Front License Plate Bracket Yaris_Fan Cosmetic Modifications (Exterior/Interior) 11 12-31-2008 09:04 PM
How can I cover front license plate hole hans_fh General Yaris / Vitz Discussion 13 01-03-2007 12:58 PM
