Old 12-03-2012, 03:47 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Attempting to change spark plugs
What is the OEM spark plug number? Are they rebranded denso or NGK? Possibility an alternative for cheaper option then?
And do you pre-gap them before install since every manufacturer is made different than the gap for Yaris.
Thanks
caineroad is offline   Reply With Quote
Old 12-03-2012, 04:00 PM   #2
Perpetuous_Dreamer
Drives: Yaris 2007
I went with NGK, pretty much happy about them. I had an issue with my Yaris when it went through the gears quite roughly, spark plugs change resolved the problem. By the way, it took me about 10 minutes to change it (first time ever), so save your money and do it by self
Perpetuous_Dreamer is offline   Reply With Quote
Old 12-03-2012, 04:42 PM   #3
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
I changed mine at 60K with NGK IFR5T11, did not gap. Very easy and quick. Use anti-seize on the threads and die-electric grease on the post. Car runs great.
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
Old 12-04-2012, 10:26 AM   #4
nookandcrannycar
Thanks
FYI, YMMV, I found the price difference between the OEM plugs and the cheapest alternative I could find to be negligible. i don't use the word negligible lightly at all. As Steve Martin's character (George?) in Father of the Bride 2 stated when he didn't want to write Eugene Levy's character a check for $100,000 to cancel the sale of his house (and it was about to be struck by a wrecking ball) - 'You don't understand, I'm the cheapest man in the world'. I laughed because I'm in touch with that way of thinking.
Old 12-04-2012, 03:37 PM   #5
edmscan
edmscan's Avatar
Drives: 2020 Corolla
You must love the show "Extreme Cheapskates". I know personally it is one of my favorite shows.
edmscan is offline   Reply With Quote
Old 12-04-2012, 07:46 PM   #6
nookandcrannycar
. I haven't seen it recently, but I do!
Old 12-05-2012, 06:41 AM   #7
motorking
Drives: 2004 CTS-V, 1997 Wrangler,
spark plugs
Thanks
Hello,
I am the tech manager at Autolite spark plugs. You will find our XP3924 Iridium spark plug a fine addition to your yaris. Faster starts, better fuel economy and 100k durability for less than the price of NGK or denso. Find them at Canadian Tire or Parts Source stores. They are gapped at .044 from the factory and can be installed as is.
motorking is offline   Reply With Quote
Old 12-05-2012, 07:21 AM   #8
just get iridiums @ canadian tire....they have a book thatll tell you which you need for your yaris
Old 12-05-2012, 08:58 AM   #9
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
+1 I ran NGK iridiums on the yaris, and they worked great!
Old 12-05-2012, 11:23 AM   #10
clarenceie
Drives: Yaris Sedan
Did the new spark plugs make a difference? Just want to know your experience. I still have the originals at 100k mi... Thanks
clarenceie is offline   Reply With Quote
Old 12-10-2012, 08:46 AM   #11
xbalance
Drives: stock
im checking for some spark plug can yaris possible to use a non resistor plug?
xbalance is offline   Reply With Quote
Old 12-11-2012, 12:31 PM   #12
RedRide
RedRide's Avatar
FWIW.......
My '02 Celica came stock with NGK plugs.
At abouit 50k miles, I replaced them with Denso plugs and there was absolutely no difference in performance.
Old 12-12-2012, 07:10 AM   #13
on 4bangers i chance plugs every 80000km and notice a big difference in power delivery...
Old 12-12-2012, 09:56 PM   #14
caineroad
caineroad's Avatar
what is the socket size for oem spark plugs?
Old 12-14-2012, 02:23 AM   #15
caineroad
caineroad's Avatar
5/8 size
just changed it today at 120,000km.
plugs look completely normal, don't think they need replacing, they were also iridium from factory.
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
