Old 12-11-2012, 06:16 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
pics of fuel pump assembly
anyone have some pics or video of prying off the fuel tank /filter/sender unit/ cap assembly
in the back seat ,that is glued on..?? I need to see some detailed pics on whats in there step by step...
yaris9876 is offline   Reply With Quote
Old 12-11-2012, 06:29 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
CTScott has posted some pics in a thread. Search and I'm sure you'll find it.
Old 12-11-2012, 09:22 PM   #3
The first time you take it off it is a bit of a bear. I use a very wide flat blade screwdriver to pry up one area enough to break the seal of the black goo. Once you get it started you can get a finger under it and flip it right up. Just be careful not to bend it with the initial prying, otherwise it will leak when you put it back on.
Old 12-12-2012, 10:40 AM   #4
yaris9876
thanks for the pic. when I get that off ,how does the white plastic thing come off??
Do you lift up the whole thing at once or pull 1 part at a time.???Does it unscrew or just pull?
I would think the seal would come from the plastic thing rather than the goo....
additional pics would be great..
What would I expect to pay for a new filter??? Autozone
Old 12-12-2012, 12:40 PM   #5
The top of the tank has a ring that screws on. Toyota makes a special ($300) spanner tool to remove it, and you may be able to find a generic tool from an auto parts place. I use a 3/4" x 3/4" x 12" long piece of hard wood and a hammer to rotate the ring loose (and to tighten it later). The black goo is just for sealing the metal cover. The tank itself has a giant o-ring to seal it.
Here is the ring removed with the O-ring visible:
Here is the connector being removed:
Here is the fuel line being removed by releasing the locking clip:
Here is the vent hose being removed by releasing the locking clip:
Here is the sender unit, which you can lift right out of the tank once you loosen the ring and disconnect the three above:
The plastic clip on the top of the lower portion of the sender is what holds the pump assembly in place. Once you pop the clip you can pull out the pump. I thought that the mesh strainer on the bottom was the actual filter, but everyplace that sells the filter sells the plastic housing that surrounds the pump as the filter. I suggest blasting the strainer with compressed air to clean it as well.
Rockauto.com has the best price on the filter assembly at $23 (elsewhere it runs about $40):
http://www.rockauto.com/catalog/rafr...998768-1370776
Old 12-12-2012, 03:22 PM   #6
yaris9876
thanks excellent photos Yes the plastic can IS the filter,
I should replace the pump and regulator also.
Old 12-12-2012, 04:15 PM   #7
What is the actual issue that you are having?
Old 12-12-2012, 07:50 PM   #8
yaris9876
my hatch has 350K on it..all original except new cam gear which really only needed cleaning.
Old 12-12-2012, 09:35 PM   #9
In that case, if you are going in there to change the filter, you might as well do the rest.
Old 01-14-2013, 10:17 PM   #10
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
So this is located directly under the rear seat in the 07 hatch models right?
Old 01-14-2013, 10:33 PM   #11
Correct.
Old 02-02-2013, 05:50 AM   #12
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Interested fuel filter part number
I like very much travel
MickZEL is offline   Reply With Quote
Old 02-02-2013, 11:38 AM   #13
Toyota only sells it as part of the whole fuel sender assembly. You can buy aftermarket ones such as the Beck/Arnley 0433008 for about $20.
Old 02-02-2013, 11:48 AM   #14
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
that number is sought only bolt
Scott, you have a picture of this filter?
Old 02-02-2013, 11:25 PM   #15
That number is not a Toyota part number, it is the Beck/Arnley part number.
Old 05-16-2013, 01:59 PM   #16
sansag13
Drives: 2009
Hi Guys,
I have 2009 toyota yaris with ~65K Miles. I tried to look for the Fuel filter part# on RockAuto but it looks like they have the fuel filter for 2008 but not for 2009. I am not able to find 2009 fuel filter anywhere.. Does fuel filter assembly is totally different in 2009 compared to 2008? or I will have to replace entire fuel pump..
sansag13 is offline   Reply With Quote
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 10:20 PM
Pics of my old water pump out of the car showing where it leaks auxmike DIY / Maintenance / Service 8 11-11-2010 01:51 PM
Unboxing pics of a new Yaris water pump... auxmike DIY / Maintenance / Service 11 11-07-2010 08:00 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
