Old 01-03-2013, 11:51 AM   #1
bone197
Drives: yaris
Scuttle panel removal / waterjet installation
Hi All
I own a Second Generation 58 plate Yaris. My passenger side windscreen waterjet was pulled off by a monkey at Longleat yesterday
I have bought the new part from my local Toyota dealership but want to install it myself. They say the scuttle panel (sp?) needs to be removed to access the hose and reinsert the component. Anyone have any experience of this?? Any advice on how to do this??
Many thanks in advance.
Bone.
bone197 is offline   Reply With Quote
Old 01-03-2013, 12:00 PM   #2
You can remove the part that is over the battery by just releasing the clips, which are visible with the hood (bonnet) open.
The two larger sections require removal of the wiper arms. To remove the one where you need to replace the nozzle, pop the cap on the wiper arm that covers the bolt. You can do this by getting a small screwdriver or your fingernails under the edges of it. Then, remove the nut and lift of the wiper arm. Now you can release the tabs that hold that part of the plastic cowling and find the hose.
2012 yaris 2d door panel removal Cryodrake Cosmetic Modifications (Exterior/Interior) 7 12-03-2016 03:47 PM
DIY rear Interior panel removal 09 3dr LB bkndacn Cosmetic Modifications (Exterior/Interior) 10 03-11-2013 01:05 AM
Yaris 1.0L GS 2000 Driver's Door Panel Removal milooshea DIY / Maintenance / Service 3 01-30-2011 12:20 PM
Back door panel removal ('00 Vitz) HELP ! Demon DIY / Maintenance / Service 2 09-27-2010 08:42 PM
