View Poll Results: Is it work it?
Yes 2 6.67%
No 28 93.33%
Voters: 30. You may not vote on this poll
Old 01-05-2013, 09:55 PM   #1
sternz
Drives: 08 Blazing Blue LB
(Cheap from ebay) Magnetic Fuel Saver
Has anyone used one of these? If so do they really make any difference at all, or are they just a waste? I was just browsing on ebay and noticed these.
this is part of their description;
1) Powermag: Magnetic Fuel Saver can help engine to burn fuel more efficiently
2) Powermag: Magnetic Fuel Saver let your car run more miles per gallon
3) Powermag: Magnetic Fuel Saver will improve engine performance
4) Powermag: Magnetic Fuel Saver will reduce emissions
5) Powermag: Magnetic Fuel Saver will clean air
Magnetic Fuel Saver gadgets increase combustion efficiency for a cleaner burning engine. This reduces harmful emissions while increasing engine performance.
Benefits of Magnetic Fuel Saver
1) Save fuel, save $$, more MPG (miles per gallon )
2) 50% reduction of carbon monoxide and hydrocarbons
3) Helps pass emission testing/smog check
4) High octane performance with lower octane fuel
5) Improved performance - quicker starts
6) Stops scale build-up and corrosion in engine
7) Reduced wear on O2 sensor and catalytic converter
Any info is welcomed! Thanks in advance.
sternz is offline   Reply With Quote
Old 01-05-2013, 09:59 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Are you talking about this one or something similar? Buy it! Doubles as a penis enhancer.
Old 01-05-2013, 10:14 PM   #3
sternz
I talking about similar, like this one! LOL!
Old 01-05-2013, 10:20 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
That's the magnetic clitoris enhancer.
You can tell by the opening.
Old 01-05-2013, 10:23 PM   #5
sternz
Old 01-06-2013, 02:54 AM   #6
mr_miles
Drives: 2013 Yaris
They forgot to add things like
adds 5-10 HP, and other misc stuff like turning your car into a hybrid and giving it the ability to make you grilled ham and cheese sandwiches while you drive, while simultaneously doing your dishes and your neighbor kids homework!
didnt this start out as some sort of farmer's trick for something a long time ago?
Old 01-06-2013, 08:28 PM   #7
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Add that to the electric supercharger:
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 01-07-2013, 01:27 AM   #8
mr_miles
Drives: 2013 Yaris
those remind me of my friend...he wanted to attach an electric blower to his intake to act like a supercharger.....I love him to death, even when he's being silly, lol.
Old 01-07-2013, 03:47 AM   #9
*MAD DOG*
*MAD DOG*'s Avatar
I had a friend who bought one of those two years ago*. He hasn't had to refuel his car since, it's pays his registration and turned his car into a hover car.
*May or may not be true.
Old 01-07-2013, 05:29 PM   #10
MadMax
MadMax's Avatar
Which one of you clowns voted 'yes'?!?
Old 01-08-2013, 03:13 AM   #11
*MAD DOG*
*MAD DOG*'s Avatar
This is an open poll. If you click on the number 1 next to yes it will tell you who voted yes.
Old 01-12-2013, 06:15 PM   #12
sternz
You guys are hilarious!
Old 01-12-2013, 10:25 PM   #13
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
MADDOG
, get your facts straight!
The hover car upgrade only works on a DMC-12...
So, unless your car looks like this:
you will not be able to use the Powermag Magnetic Fuel Saver to get your car into hover mode...
(It has something to do with the interaction with the stainless steel body work of the DMC-12 and the magnetic fields generated when the Powermag is optimizing fuel flow.)
Old 01-15-2013, 02:45 PM   #14
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
I do believe this is yet another scam to lighten the wallets of the unsuspecting. For me, I shall pass on this particular fuel economy enhancement.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 01-19-2013, 07:11 PM   #15
charles nelson
Drives: red Liftback
Air Swirler...
The gas line magnet...reminds of a device that a friend of mine put in his carburetor. It looked like an aluminum turbine blade. It was supposed to 'swirl' the air as it went through the carburetor throat to better mix the gas with air.
He found no change in mileage until one of the blades broke off and went into the engine. He didn't use any more gasoline until they took the engine apart to repair it.
charles nelson is offline   Reply With Quote
Old 01-19-2013, 08:39 PM   #16
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by jpmck03 View Post
MADDOG, get your facts straight!
Attachment 49549
They used to call DeLoreans "snowmobiles" because it took coke to get them running.
Old 01-20-2013, 12:28 AM   #17
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Hahaa.. This junk has been around as long as the automobile. Even the manufacturers aren't above such rubbish, look at some of the ads from the 40s and 50s to see what I mean. Mr. Nelson is right...
Old 01-20-2013, 02:54 AM   #18
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Absolute waste of money, will do absolutely nothing to improve any aspect of your cars performance.
Most car companies have billion dollar research and development departments dedicated to getting the best performance out of a car,odd gimmicks like the one here have usually been tried and tested and found to be useless,if they did anything at all you can bet they'd be standard equipment on most cars.
Have Yaris will travel..
fuel saver, magnetic
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
