Old 01-17-2013, 09:20 PM   #1
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
DIY Fuse Block.
I've been using these Blue Sea fuse blocks for close to 20 years. I seem to buy a car, and within a few weeks start adding things.
So for I've got the Hella horns, Alarm and stereo. I will be adding relays to the headlights and some fogs/driving lamps.
So today I bought one of the smaller BS fuse blocks, and found the perfect spot for it!
I'll wire it up on the weekend.
UberSilver is offline   Reply With Quote
Old 01-17-2013, 09:26 PM   #2
Very nice!
Old 01-18-2013, 12:34 PM   #3
TOLMACH
Drives: soarer
Sorry for off-topic
The yellow fuse in the right hand corner is the one that needs to come out before cranking the engine to de-pressurize the fuel system (in case one needs to do smth with the fuel injectors, etc and not get fuel spills)?
Thanks
using the same spot for my fuse
http://photo.qip.ru/users/tolmach/96608749/126157539/
Old 01-18-2013, 01:29 PM   #4
Originally Posted by TOLMACH View Post
Sorry for off-topic
Thanks
Correct
Old 01-18-2013, 06:02 PM   #5
TOLMACH
Drives: soarer
^ Thank you!
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
DIY Powered USB Ports BailOut DIY / Maintenance / Service 27 02-22-2017 10:17 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 06:53 PM
