Old 01-24-2013, 07:09 AM   #1
SilverSquash!
Stage ...Base
SilverSquash!'s Avatar
Drives: Toyota Yaris LB '07
Is this a foglight stalk?
Okay this is the stalk in my yari
I think it is a fog light stalk but the only problem is that the part that supposed to move ie the switch on the right doesn't move, is there a tab that supposed to be broken to allow it to move?
Also I have Dlala fogs and want to connect it to the stalk if possible, note I have an aftermarket switch at the moment controlling the fogs, what do I need to do in order for it to work?
Thanks people
SilverSquash! is offline   Reply With Quote
Old 01-24-2013, 08:24 AM   #2
With the symbol facing in the opposite direction as the headlight symbol, I believe that is the rear foglight switch (some European Yaris have rear fogs). I have a European Yaris instrument cluster and it has two fog light indicators - One facing the same direction as the headlight indicator and one facing the opposite.
Since the switch does not rotate, I would continue using your fogs as is, rather than risking breaking the internals of the headlight switch.
Old 01-24-2013, 08:27 AM   #3
SilverSquash!
Stage ...Base
Thanks CTScott, appreciate the help, I'm just going to carry on using them normally...also hear in SA the yari's come with rear fog lights
Old 01-24-2013, 11:08 AM   #4
SePtRa
Drives: 2000 Land Cruiser & 2007 Yaris
Hi,
In European cars with the stalk that you have you can only turn the stalk when the headlights are turned on.
As CTScott said that switch is for rear fog lights
I have the same stalk on my 2007 Yaris.
SePtRa is offline   Reply With Quote
Old 01-24-2013, 12:39 PM   #5
SilverSquash!
Stage ...Base
Hey SePtRa,
Mine doesn't move regardless if the headlights are on or not, but I know the rear fogs come on, I think our cars have their rear fogs permanently on when the headlights are on
DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) CTScott DIY / Maintenance / Service 142 06-25-2024 01:47 AM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Headlight Stalk jpmck03 DIY / Maintenance / Service 24 06-19-2010 04:51 PM
WTB: 06 Hatch Foglight Covers (non foglight) hasher22 Willing to Buy by private party 2 06-24-2009 12:35 AM
Foglight Switch Yarii Cosmetic Modifications (Exterior/Interior) 12 09-26-2006 04:20 AM
