Old 01-29-2013, 09:43 AM   #1
inertia420
Drives: 2000 Toyota Funcargo
Headlight question...
So I currently live in Japan and drive a Funcargo...I've found lots of items and as soon as spring comes along I want to start working on it. The only thing i havent found are ccfl/halo headlights for it. I've been told that the statside Yaris or the Echo headlights would fit. Can anyone clarify this issue for me? really wanna trick this out... TIA for the help!!
inertia420 is offline   Reply With Quote
Old 01-29-2013, 10:31 AM   #2
I don't believe that the funcargo headlights are the same as for the first generation Yaris/Echo. The part numbers in the Japanese parts catalog are completely different and the shape also appears different, as the funcargo headlights seem to stretch further back along the fender.
You could always go the retrofit route, where you install a set of HID projectors with the ccfl ring within your existing headlight housing.
headlight question (08 hatch) andulong DIY / Maintenance / Service 3 06-17-2012 02:10 PM
Quick headlight question. Spahrticus Cosmetic Modifications (Exterior/Interior) 6 01-31-2011 02:26 AM
Headlight question bulb sizes.. Darwin84020 DIY / Maintenance / Service 1 12-21-2010 11:00 PM
Headlight adjustment screw question. evan DIY / Maintenance / Service 6 01-09-2009 06:58 PM
Quick headlight question silverRS Cosmetic Modifications (Exterior/Interior) 3 06-21-2006 10:54 AM
