Old 02-10-2013, 08:48 AM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
15x7 30+ offset 205/50 tires will it rub in rear
Sorry to ask such a general question...have an opportunity to get a set of kosei 15x7 30 offset wheels for cheap and swap over my 205/50 tires my car is basically slammed will this rub in the rear?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 02-10-2013, 09:36 AM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
im sure you'll be fine. many people get +40offset with 10mm penguin spacers without issue. I had an effective +27 offset 16x7 on 195/50/16 tires with tuck and had no issues at all...even with our crooked rear axle beam.
Old 02-10-2013, 10:42 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
That is super subtle not aggressive at all. You should be fine
Any updated pics since you've gone lower?
Old 02-10-2013, 04:12 PM   #4
DeathBeard
DeathBeard's Avatar
using 150mm megan rear spring chppped rear shock bolt by a good 1.5 inches..The trick to lowering these more was to reuse the oem upper spring seat and lose the spring perches
BEFORE
Proverbs 16:9
Old 02-10-2013, 04:14 PM   #5
DeathBeard
DeathBeard's Avatar
After:
Diched the rear spring perches, reused oem upper top hat lowered it by an extra 1inch, once this settles it will be highly tucked, though I am dissapointed with the free travel of the megan yaris shock..I am looking into the Function and Form or D2 offering for the 07 Honda Fit as they are shorter by a good 20mm than the yaris
Proverbs 16:9
Old 02-10-2013, 04:16 PM   #6
DeathBeard
DeathBeard's Avatar
Running 2 sets of oem toyota camber bolts in the front (2 camber bolts per wheel) I would conservitively put this at -3..no more fender liner issues..May slot the strut holes if I ever man up and get the TR Motorsport 15x9 36+ offset wheels
Proverbs 16:9
Old 02-10-2013, 04:17 PM   #7
DeathBeard
DeathBeard's Avatar
A trip down memory lane....my old ep3 running -5 camber with buddy club coilovers, J'sRacing DC5 tie rod ends, full hfp kit with 03 tailight swap, k20a swap..A top knotch car with top knotch memories
Proverbs 16:9
Old 02-10-2013, 04:22 PM   #8
DeathBeard
DeathBeard's Avatar
I miss my ep3 but the vitz is growing on me just wish you could use camber plates and lose the crap torsion beam
Proverbs 16:9
Old 02-10-2013, 04:24 PM   #9
DeathBeard
DeathBeard's Avatar
RIms for sale $300 pick up
Proverbs 16:9
Old 02-10-2013, 04:26 PM   #10
DeathBeard
DeathBeard's Avatar
Mugen wing, with stock 04 tailights..1 month after I got her on Progress Coilovers, a good coilover sadly no camber plates
Proverbs 16:9
Old 02-10-2013, 04:45 PM   #11
DeathBeard
DeathBeard's Avatar
my old 07 yaris with Type S front lip, on tein basics, not a good coilover imo, these are maxed and still not low and too softly valved/sprung
Proverbs 16:9
Old 02-10-2013, 05:49 PM   #12
1.5
Form>Function
1.5's Avatar
Nice cars lol I still use my 130mm rears springs with the shocks set longer and no issues
Old 02-10-2013, 07:10 PM   #13
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
My car with 15x7+25mm wheels and 205/50/15's:
No rubbing issues. Could still go a little lower also. I did pull and roll my fenders far enough to clear 225/45/15 tires on the same wheels.
Old 02-10-2013, 09:04 PM   #14
DeathBeard
DeathBeard's Avatar
Lol I know you run your springs like that 1.5 but I am unsettled about it for some reason..
tougeghost awesome man
Proverbs 16:9
Old 02-13-2013, 06:00 PM   #15
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Am i correct in gathering that 205/50/15s wont be a problem for a car that is lowered 1.8 inches?
and is there a preferred offset range to use?
What will it take to make 15x7 +27 offset wheels fit Yaris? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 11-28-2010 02:32 AM
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 08:24 AM
