Old 02-23-2013, 04:46 PM   #1
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
oil grade..
hi need to know , what is good for my car engine oil? the grade and mineral or synthetic? i am a bit crazy about this, i searched on google and non sense...too much vice and vice versa. i got 1.0 automatic vitz. thanks.
dindy is offline   Reply With Quote
Old 02-23-2013, 04:50 PM   #2
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
There's a couple schools of thought. One is to run high quality synthetic and change once per year. Another is to run normal grade oil and change every 3 months. In the US, oil is so cheap, a lot of us use synthetic. I dont think a Yaris motor cares either way.
UberSilver is offline   Reply With Quote
Old 02-23-2013, 04:59 PM   #3
I loose track of all the arguments myself. I mostly just use whatever quality dino oil is on sale with regular change intervals. The grade should be printed on your oil cap.
I do believe that there are advisements against switching to synthetic on older high milage engines. If this is true, given yours is 11 years old, it may warrant digging deeper into this thought.
Old 02-24-2013, 03:59 AM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
A synthetic 10w-30 should be fine for your car,change every 10,000kms or once a year.
Have Yaris will travel..
Old 02-24-2013, 09:21 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
the only real arguments against switching to synthetic in older vehicles is because it will break down anything built up anywhere in the engine, and those build ups could be around something that would leak. So changing to synthetic you would all of a sudden find every single leak that would have been hidden using non synthetic oil.
Now whether that is actually a bad thing or not is another story.
Colin Chapman disciple
Old 02-24-2013, 12:38 PM   #6
dindy
still different reasons so far.....i had read about mineral vs sythetic......anyway. my haynes book about yaris it tells me to fill 0w30 or 5w30....which for my country in summer i think is too thin, cause of very high temperatures, still on the cap of my car, i doesnt says what oil should i give.
Old 02-24-2013, 01:30 PM   #7
racerb
I used to be an Amsoil Dealer and if the owners manual has a chart showing recommendations, go by that, it is what they test their engines with. I run 5w-30 synthetic in Yaris and 10w-30 synthetic in my Tundra, changing it out around 7,500 miles, but the real key is to use the best filter possible! After seeing some recent filter cut-away tests, the Toyota OEM is your best choice, but K&N and Royal Purple make a great filter also, just more expensive than OEM.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-24-2013, 02:04 PM   #8
NJ Drive
Drives: 2012 Yaris SE
Walmart: 5w30 Mobil 1 Synthetic 5 quart container= $25
Good for at least 5000 mile intervals. This car doesn't require much thought when it comes to oil.
Just realized you're not in the USA, but still food for thought for people stateside.
NJ Drive is offline   Reply With Quote
Old 02-24-2013, 06:14 PM   #9
That is because there is no definitive answer. Most veterans of this forum roll their eyes whenever yet another oil question is raised and move on. Hence the reason this post is only the 7th reply.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
