Old 03-14-2013, 02:23 PM   #1
Yarflana
Drives: 2008 Base Model
Address rubbing with DF210s
Ok. Installed DF210s and have some minor rubbing on the front.
Wheel/tire combo is 16x7; 205/50/16. I don't know the offset, but the tires are right at the edge of the fender well, not inside, not outside.
The rear is ok and has minor rubbing only with major dips and I have set my Tokico reds to 2+ full hard to handle that.
The front is another story with what's inside the fender well.
I have heard of folks tearing out some part of their fender wells to help with rubbing issues, but I don't know exactly what they are tearing out.
Any advice is welcomed.
Pat
Yarflana is offline   Reply With Quote
Old 03-14-2013, 03:25 PM   #2
Yarflana
Ok read about fender rolling...I think the baseball bat or other similar method would be helpful, if I need to go that far.
For now, I think I just need to make sure everything is tidy in the wheel wells. I saw today that the driver side fender liner was bowed out over the tire and it was rubbing at every bump in the road! I pushed it in some and that helped. I will take a rubber mallet to that tonight. The other side is good and tidy.
The front is where I will need to get smart.
Old 03-14-2013, 03:33 PM   #3
195/50/16 rubber if you want to avoid bastardizing your car.
Old 03-14-2013, 03:35 PM   #4
Yarflana
Not changing the rubber. If I cannot make it all work eventually, I will put the Eibachs back on.
Old 03-14-2013, 03:37 PM   #5
Yarflana
I get the sense that guys who are concerned about fender rub are trying to run with a softer ride.
If I don't care about a softer ride, then I can go with less clearance because I can set my shocks (I have Tokico reds) at a lower dampening/stiffer ride and not be concerned with a lot of clearance...right?
This is likely my route on the front anyways. The back has more fender clearance.
Old 03-15-2013, 01:51 AM   #6
The offset should be stamped on the back of the rims, most likely either on the hub or on one of the spokes. It'll say "ET__." Replied to your PM too. ;)
Old 03-15-2013, 03:34 AM   #7
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
If you drive it long enough it will likely wear itself in the right places. The tires are stronger than the liner.
-Type 07 FFL-
My odometer 03/11
Old 03-15-2013, 10:29 AM   #8
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I run the same size wheels/tires. That's the main reason I've been leery to lower any more. When I turn left at full lock I scrub in the front. I used the baseball bat method to roll my rear fenders to get rid of that scrub when you hit a large bump.
Old 03-15-2013, 08:50 PM   #9
atxsteve1
Drives: THE RED HATCHY
i dont get how you are rubbing my car is lower than yours. I was running 18x7.5 and 215/35 with 2 inch drop springs before.
atxsteve1 is offline   Reply With Quote
Old 03-16-2013, 04:17 AM   #10
Do you know exactly where it's rubbing?
Is it on the liner,or on the metal fender?
3 ways to fix rubbing in front:
1. Use a razor to trim just the bit of plastic liner that is rubbing. (put blue tape on the liner and drive around to find out exactly where that is).
2. Add some negative camber to your front alignment (-1 degree improves handling and can help with rubbing)
3. Roll the fenders. Have it done professionally, it's cheap and won't hurt your paint. A baseball bat will.
Old 03-16-2013, 11:36 AM   #11
mazilla
advocatus diaboli
mazilla's Avatar
Speaking of #3...
I went to have my fenders rolled yesterday and the eastwood roller wouldn't adjust short enough to roll em...sucks arse.
-Type 07 FFL-
My odometer 03/11
Old 03-17-2013, 09:17 AM   #12
3cyltrbo
+1
3cyltrbo is offline   Reply With Quote
Old 03-18-2013, 12:03 PM   #13
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Get some camber bolts from micro image. Tell them that Marlondog sent you.
marlondog is offline   Reply With Quote
Old 03-29-2013, 11:23 AM   #14
47_MasoN_47
Will camber help scrubbing the metal part that is kindof behind the wheel? When I turn to the left at full lock I scrub that thing pretty hard. I've knocked a fair bit of the paint off so I know exactly where it's rubbing, haha. The steel looks fairly thick there so I don't know if it would be safe to just dremel a notch out or not.
Old 03-29-2013, 12:03 PM   #15
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I am not seeing what youre trying to describe. Any pics?
Negative camber would tilt the wheels in so if you are rubbing on the inside, camber may make it worse
Old 03-29-2013, 12:12 PM   #16
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I agree. My wheels have a deep outer rim so I chose 195/60/15's to completely avoid any rubbing issues. 60 series tires also offer higher treadwear numbers and will last longer.
Old 03-29-2013, 12:13 PM   #17
47_MasoN_47
Old 03-29-2013, 12:14 PM   #18
1.5
Form>Function
1.5's Avatar
With how low that is compared to the wheel, negative camber should help tilt the wheel enough to space away from that portion. spacers would help too
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
Will Rubbing Occur on DF210's/ Motegi 17x7, ET40 with Nexen n3000 205/40ZR17 areithan1980 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-16-2009 10:52 AM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
"Bouncy" Ride After DF210s? MadMax Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 05-12-2009 10:04 AM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 05:09 PM
