Old 03-19-2013, 09:30 PM   #1
goose1uponu
goose1uponu's Avatar
Drives: 2009 Sedan
Transmission
In the morning when I first drive my Yaris, the transmission won't go to the last gear for the first mile or so, then it works perfect the rest of the day. Is this an issue with the 2009 Yaris Sedan, should I get rid of the car?
goose1uponu is offline   Reply With Quote
Old 03-19-2013, 09:57 PM   #2
This is covered in about 100 threads (and your owners manual). The Yaris auto tranny prohibits shifting to 4th until the coolant and AT fluid temperatures reach a threshold.
Old 03-19-2013, 10:04 PM   #3
Yarflana
Drives: 2008 Base Model
Yep, part of the initial warming up period for the engine/transmission. Nothing to be concerned about.
Yarflana is offline   Reply With Quote
Old 03-20-2013, 03:13 AM   #4
yariseggvvti
Drives: Yaris Hatchieback
what if when it warm it up and I had been drive a while. When the vehicle is shift, the rpm just up and shift in gear. Is this will do anything with shift solenoid? I notice there is three shift solenoid attach to the transmission.
yariseggvvti is offline   Reply With Quote
Old 03-20-2013, 04:41 AM   #5
joshthorsc
Drives: 2012 Yaris SE 5spd
Even my old 2004 tundra did the same thing on cold starts. It'll linger onto lower gears for a while longer until it warms up and then it'll go into fourth gear. My wife's 2005 sienna does the same thing.
2013 Tundra CM Rock Warrior
1991 MR2 Turbo
2012 Yaris SE 5spd...Daily Driver
joshthorsc is offline   Reply With Quote
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
need experts helo on robotic transmission clutch mariann DIY / Maintenance / Service 0 10-03-2012 12:51 PM
Transmission & Reverse Twistoffate0817 DIY / Maintenance / Service 4 08-28-2012 06:50 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
Installing a external in line transmission filter. YarisSedan Performance Modifications 1 03-31-2009 08:03 PM
