Old 03-27-2013, 03:55 PM   #1
kyonic
Vibration at idle or at a stop
Hello I have a 2008 Yaris sedan and I have noticed a vibration or buzz in the car. This happens when I am at a stop sign or light and when the car is idling. Is this normal? Should I take a look at something. Well anyway just looking for ideas. Thanks
kyonic is offline   Reply With Quote
Old 03-27-2013, 04:40 PM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
I might be wrong on this, but from what I understand and people have noted. The car gets pretty low when stopped. It drops down to 500rpm I think. This weak idle gives you a shudder in the car. The car is programmed like that to minimize gas usage when idling. Once again not 100% confirmed.
Its a Chao!!!
Old 03-27-2013, 05:02 PM   #3
vadr45
vadr45
vadr45's Avatar
Drives: 2009 Base 3-door
Check out the thread at page 2 (below) titled something like "Shakes at Idle" - all will be made clear.
vadr45
Alexandria, VA
2009 Black Base 3-Door Yaris
1950 Austin A70 Hampshire
vadr45 is offline   Reply With Quote
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 12:58 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
2010 Yaris Idle Stop Function ? Nu18F New YARIS Purchase Forum 6 02-12-2009 06:46 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
