Old 03-29-2013, 03:43 AM   #1
yaitsme
Drives: 2008 Yaris
replacing VVT - HELP
Hello, I got a P0010 code right after I tightened the S belt. I guess I broke the VVT connector according to other post I've read. Is this part easy to replace? If so How do I do it. Any help would be great. Thanks
yaitsme is offline   Reply With Quote
Old 03-29-2013, 06:19 AM   #2
It is very easy to replace. There is just one bolt that mounts it to the side of the block.
Old 03-29-2013, 11:30 PM   #3
yaitsme
Drives: 2008 Yaris
OK, Do I need to worry about placement or adjustment or is it a straight forward remove and replace.. I will try to remove it in the morning, Thanks
Old 03-29-2013, 11:44 PM   #4
The only thing you need to do while installing it is to coat the o-ring with oil. You don't have to worry about positioning it.
Old 03-30-2013, 01:37 AM   #5
yaitsme
Drives: 2008 Yaris
Thanks CTScott, I will try it in the morning
Old 03-30-2013, 07:22 AM   #6
bronsin
bronsin's Avatar
Can you explain where the connector is and how you broke it so I dont do it?
THANKS!
Old 03-30-2013, 11:04 AM   #7
yaitsme
Drives: 2008 Yaris
The connector is right above the alternator, I used a small crowbar as leverage to pull back the alternator as I tightened the bolt on the alternator and the connector is right there so be very careful not to slip.
Old 03-30-2013, 11:04 AM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
It seems like 7/10 break this way...
-Type 07 FFL-
My odometer 03/11
Old 04-02-2013, 11:56 PM   #9
yaitsme
Drives: 2008 Yaris
I was able to remove it easily and inspect it. YUP I broke the connector to the solenoid coil. I've been driving it for a couple of weeks this way and I don't notice any difference at all. What exactly does this vvt do and am I hurting the engine any by driving it? I bought one off of ebay because its way too expensive from a dealer and I could not find it at any local auto parts store. I should get it in a couple of days.
Old 04-03-2013, 05:56 AM   #10
bronsin
bronsin's Avatar
Alter the valve timing. I have no idea if it would hurt the engine or not if the VVT is disabled. Perhaps it affects mileage either better or worse?
If its better without and it doesnt hurt anything we've got another mod!
Old 04-03-2013, 01:52 PM   #11
esse10
Drives: 2009 yaris 2 door
vvt
THANKS!
yea can you show us a pictures of this vvt so we don't go around making the same mistakes in the future.........
Old 04-03-2013, 03:28 PM   #12
bronsin
bronsin's Avatar
Connector at the top of the picture between the black hose and the black plastic valve cover.
Old 04-04-2013, 11:44 PM   #13
yaitsme
Drives: 2008 Yaris
Thats a good picture bronsin, It's right there. Yeah, I don't notice any difference in performance or mileage but there is that pesky "Check Engine" light on all the time so
I will need to replace it.
Old 04-05-2013, 10:00 AM   #14
bronsin
bronsin's Avatar
Does anyone know if it hurts the engine or not to drive without the VVT and the CEL on?
Im thinking in the future if mine ever goes and it does no harm I'll just drive it!
Replacing most of the braking system...hints or suggestions Yarflana DIY / Maintenance / Service 10 03-15-2013 10:39 PM
Replacing drivetrain bankrobber DIY / Maintenance / Service 5 09-09-2011 04:42 PM
Replacing factory fog lights? jmk1983 DIY / Maintenance / Service 4 10-13-2010 04:39 PM
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-01-2010 11:13 PM
At what RPM VVT should be activated? Parmas Performance Modifications 30 11-19-2009 07:40 PM
