Old 04-02-2013, 07:04 AM   #1
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
HIDs faulty?
Hey everyone,
I've had HIDs on for about 3 month now and last week I noticed the light output seemed to be an actual blue rather than the 6000k white. I got in touch with the seller who I had the bulbs from asking for a replacement as I'd had some flickering too. He suggested it was the ballast and that I replace them with the canbus ones. I replaced the ballasts and now the lights are completely white which was a shock but last night the left one went out - I turned off my lights and back on again and they both worked. Do I need canbus ballasts or was the seller trying to just get another sale? As far as I was aware, the ballasts I was using were canbus but he wanted to sell me some for nearly £40 just for ballasts. I should point out that I'm using a bi-xenon relay that goes into the stock light fitting also and not to the battery. Could this be an issue? Don't really want the lights going out on me on a dark road!
Thanks!
Eren_13 is offline   Reply With Quote
Old 04-02-2013, 08:16 AM   #2
I'd check to see if they're flickering while you have the car on but the lights running as DRL's (assuming you have DRL's in the UK) have the hood popped and see if you can hear the relays clicking on/off fast. Actually, do you have a PC of the kit/wiring/ballasts?
Old 04-02-2013, 08:40 AM   #3
Eren_13
Eren_13's Avatar
We do have DRLs over here but I don't have them fitted. I ran the lights just now and only get a click from the relay when using high beam.
Photos below.
And rather terrifyingly, I've just seen this at the top of the headlight reflector!
What is that?? Please tell me it's not burning my reflector.
Old 04-02-2013, 10:59 AM   #4
Eren_13
Eren_13's Avatar
Been reading up on canbus HIDs and could the flickering be down to the ballasts not actually being canbus compatible or does the Yaris not need them?
I've been seeing the canbus decoder / error cancellers too. These claim to stop the flickering. Could this be?
Thanks.
Old 04-02-2013, 01:01 PM   #5
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Sounds like you bought a cheap kit. ballast went bad and killed a bulb. The cheap bulbs are out gassing, leaving the gas on your reflector.
UberSilver is offline   Reply With Quote
Old 04-02-2013, 02:01 PM   #6
Eren_13
Eren_13's Avatar
Poop. Well that's not very good is it :( in all fairness, it wasn't actually that cheap. Got it from a 'shop' which came up on google which is annoying.
So is that basically a whole new kit? Weirdly, the bulb is working but a slight flickering still. Only every now and then, not all the time.
Old 04-02-2013, 02:21 PM   #7
UberSilver
UberSilver's Avatar
Over the last 6 years I've bought about ten kits from these guys, and there always top quality.
http://www.retro-solutions.com/
Old 04-02-2013, 02:21 PM   #8
It COULD be a bad bulb that is making the ballasts die. I'd also check the ground for that headlight wiring. Additionally, swap ballasts side-side to see if the issue moves.
Old 04-03-2013, 08:45 AM   #9
Eren_13
Eren_13's Avatar
Thanks! I'll check them out.
I'll double check the ground. Like I say, I'm using the existing ground in the form of a relay using the origins, headlight connector which is in turn connected to ballast and bulb. No actual connection to the battery or separate ground.
I've moved the bulbs and ballasts, still appear to flicker. I'm in touch with the seller but it may be worth my while just trying out some new bulbs to be honest. Don't like the look of that outgassing though, I hope it wipes off somehow.
Old 04-03-2013, 07:30 PM   #10
Both flicker? I imagine you have daytime running lights....what happens when you just turn ON the headlights?
Old 04-05-2013, 08:07 AM   #11
Eren_13
Eren_13's Avatar
At the risk of misunderstanding - engine on, headlights on, no DRLs = slight flicker. Strangely seem to be getting better with time (don't want to speak too soon) and engine off, headlights on, bit more flicker. I'm wondering if its these H4-3 bulbs that I'm using and that my car doesn't like the bulb moving back and forth for hi/lo?..wonder if its worth giving the H4-2 bulbs a go, see if that works it out.
The forever growing to do / to buy list:
FIX Projectors - FINALLY DONE!
XB LED fogs - Done
Lowering springs - Done
MOMO Revenge Evo X - Currently selling body parts for
Declare bankruptcy - Done
installed some 3000k HID's thebarber Photo-Video-Media Gallery 17 01-22-2010 09:45 AM
Rubber cover over HIDs... Kioshi Cosmetic Modifications (Exterior/Interior) 9 12-20-2009 09:54 PM
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 10:21 AM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
NEW HIDS 10000k!!!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 69 01-26-2007 12:12 PM
