Old 04-30-2013, 04:59 PM   #1
Melloreel
Drives: 08 3dr LB
Blower motor? "Here we go again"
Ok. The blower motor stopped working yesterday. First time since I purchased car. I opened the cabin filter to look for blockage. None found. Then I turned the cage by hand, and it started working fine. Now today "hot as fire in Georgia"
It stops again? So I open the fresh air vent, then drove to highway speed to see if outside air would move motor enough to start! It did.
Now ? How much trouble to change out blower motor? Let me guess. Pull engine and transmission, also rear tires
Any idea of motor cost?
Melloreel is offline   Reply With Quote
Old 04-30-2013, 05:05 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Remove the bottom plastic panel there should be a few screws and it comes out. Should take less than 20 minutes from start to finish.
Old 04-30-2013, 05:13 PM   #3
YarisSedan
Old 04-30-2013, 05:13 PM   #4
YarisSedan
Old 04-30-2013, 05:14 PM   #5
Melloreel
Drives: 08 3dr LB
Thank you sir! I will try this tomorrow if dealer stocks motor?
Old 04-30-2013, 05:18 PM   #6
YarisSedan
Part # is 8713-52141 it lists for 135 I would try calling a local parts store and see if a aftermarket one is available most likely will be find one for half that price
Old 04-30-2013, 09:45 PM   #7
alanwagen
I took out my son's blower and unplugged and lubed it with WD40. Put it back.
I was told that I should of used silicone instead but it is working now and has been for a few weeks.
A/C Blower Dismantling? Yaross DIY / Maintenance / Service 9 12-14-2011 03:56 AM
Why wont my fan blower work? lucy7509 DIY / Maintenance / Service 4 08-09-2011 02:48 AM
09 Yaris Heater blower problem motoxxx3 DIY / Maintenance / Service 28 10-15-2010 05:45 AM
A/C blower resistor ubear7 DIY / Maintenance / Service 1 08-08-2010 09:53 PM
dead mouse in my blower unit beacon DIY / Maintenance / Service 20 11-25-2008 12:31 PM
