Old 05-05-2013, 06:34 AM   #1
regal
TRD Spings + Tokicos need camber plates?
I have TRD springs, 15" Scion aluminum wheels, and Tociko struts. The tires are P195/55/R15.
The inside of the front tires wore out in just 5k miles. I think it was just a poor alignment, or do I need to buy come sort of camber adjustment add-on?
Old 05-05-2013, 08:09 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There's a good bit of adjustibility in the stock crash bolts, and the springs/shocks will change your geometry. Considering how quickly you went through those tires, $100 for an alignment is a pretty good investment.
Old 05-05-2013, 11:51 AM   #3
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
I have the exact same setup.
Camber bolts are advisable, but the toe adjustment is more critical.
I have no camber bolts on mine, just a toe adjustment, and no wear at 5K.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 05-05-2013, 02:45 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Did you get an alignment after install? It sounds like you didn't.
Colin Chapman disciple
Old 05-05-2013, 05:37 PM   #5
BT91
BT91's Avatar
Drives: 2008 Yaris Sedan
I pretty much just installed the same setup on my sedan. H&R Springs and Tokico Shocks/Struts (whatever you prefer to call them) on 16" rims. I got an allignment after the install and the camber was almost perfect but the toe was out a bit so got that all adjusted. Also its a good idea to get an allignemnt after the springs settle cus it could go out slightly for the extra 100 bucks its well worth it over 500 for tires. Im pretty sure the drop is almost the same for TRD and H&R springs, so its most llikely a toe issue over camber. But if its a camber issue there is some adjustment range on factory toyota crash bolt setup. Hope This helps.
Droppin Gears
BT91 is offline   Reply With Quote
FEELER: Any interest in camber plates or hub spacers? bzinn 1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-17-2010 12:44 AM
With TRD Springs do I need to adjust camber? regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-18-2009 09:51 PM
My latest mod... custom plates TRD VVTI YarisSedan Cosmetic Modifications (Exterior/Interior) 8 04-16-2009 11:03 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
Camber Plates (Gauging Interest) misformartin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 01-07-2009 11:21 PM
