Old 05-12-2013, 08:42 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
limp mode?
Does our car have a limp mode if you do something the ECU doesn't like?
passing someone today, dropped it into 3rd and gave it hell, tapped the revlimiter and shifted into 4th and the CEL came on it wouldn't rev any even with the clutch depressed, gave it a few pumps of the gas and letting out on the clutch and the car came back to life and the CEL went off. scarred me thought i had blew it an hour away from home.
Old 05-12-2013, 10:04 PM   #2
I believe so. Usually happens in situations like you described. I remember reading several threads about it some time ago here.
Old 05-12-2013, 10:14 PM   #3
Yes. If you read the stored code you will likely find it was a misfire.
Old 05-13-2013, 09:31 AM   #4
Golddeenoh
Golddeenoh's Avatar
misfire = pissed off ECU :D
Old 05-16-2013, 05:16 PM   #5
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Don't take it to the red line! Power is falling off anyway at that point. I'd shift just before the red line.
Amdkt7 is offline   Reply With Quote
Old 06-13-2013, 04:54 PM   #6
Golddeenoh
Golddeenoh's Avatar
P0301 code pulled and cleared.
Old 06-13-2013, 05:08 PM   #7
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Interesting. I've let mine ping the rev limiter some (I have an auto so it shifts whenever it feels like it) while doing burnouts and haven't seen it do that. The only time I threw a CEL at WOT was before my 1zz injectors (lean).
My RS Out of Hibernation Mode Night Shoot! Freestylin Photo-Video-Media Gallery 66 12-23-2014 08:25 AM
does defrost mode affect mileage? nikvolkert Fuel Economy Forum 15 10-21-2010 10:39 PM
Summer mode is on :) 06_hbyaris Canada 3 03-23-2010 10:15 AM
