Old 05-18-2013, 03:23 PM   #1
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
HID full size ballast install?
I went to install an HID system in the Yaris, opened the hood, and thought, OhSh*t! where can I put these full sized ballast!?!
I found a great spot! Under the headlamp assembly. Install took 90 minutes and looks great(so far), I'll post night pics later.
http://retro-solutions.net/product-l...pg1-cid86.html
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 05-18-2013, 03:31 PM   #2
dumbo0
dumbo0's Avatar
Drives: Betsy - 07 Yaris HB
Where'd you get the kit if you dont mind
WILDY imaginative
WONDERFULLY expressive
dumbo0 is offline   Reply With Quote
Old 05-18-2013, 07:32 PM   #3
UberSilver
UberSilver's Avatar
theres a link in the post.
And more pics.
Old 05-19-2013, 12:16 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hmmm. Not a fan of plug-n-play kits but because of the ease of installation I can understand why they're so popular.
Judging from the cutoff pics, you may be blinding other drivers driving in the opposite direction but not realize it. A proper retrofit with a projector will definitely improve the cutoff and direction of the beam though it does require more labor which includes opening up the headlights.
Here are two threads that may be helpful as well.
Brian (sedan)
PETERPOOP (liftback)
Old 05-19-2013, 12:38 PM   #5
UberSilver
UberSilver's Avatar
I guess your not looking at the pic? the cut-off is very close to stock with a halogen bulb.
If I were blinding(on flat roads)oncoming traffic, I'd pull the system.
I've seen more glare off of OEM HID equipped cars, than this system.
I'm getting little to no stray light above the cut-off line. I would like a more defined line, but thats the price one pays for a retro solution. Of coarse a proper projector would be better, but this is good enough for now.
Old 05-19-2013, 03:39 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
ballast under the headlight you say? :)
Old 05-19-2013, 04:24 PM   #7
It's not necessarily the cutoff that's the problem. It's that the reflector bowls were designed for halogen bulbs, not HID bulbs, which emit light a different way. You may not see it, but glare may be coming from the headlights if seen head on. You'll know if you have that problem as people will either high beam you, or flip you off. I think people have made blockers that go on the bottom of the bulb to help limit the glare problem.
Old 05-19-2013, 05:17 PM   #8
UberSilver
UberSilver's Avatar
I had glare issue with my Land cruisers 4x6 headlamps. I painted the bulb holder flat black and that took care of the glare.
Old 05-19-2013, 11:34 PM   #9
I believe the stock ones are painted flat black already from what I remember when I removed mine to install the projectors. Drive around at night for a while. I mean, it's the Bay Area, someone is bound to high beam you and/or flip you off. I know I got some when I ran plug-n-play HIDs.
Old 05-20-2013, 12:03 AM   #10
UberSilver
UberSilver's Avatar
But folks have been high beaming and flipping me off since I got my Yaris(day or night).
Old 05-20-2013, 01:05 AM   #11
lol. Well then, I'm not sure how you would be able to tell unless you park the Yaris and drive another car coming from the opposite direction. I only get flipped off now for ignoring ricers wanting to race me (before it was the HIDs).
Old 05-20-2013, 01:14 AM   #12
YarisSedan
Drives: 08 Yaris Sedan
The kit I got was bi xenon when I drive in traffic at night I switch it to xenon not to pass off other drivers and when it's pretty clear road I switch back to hid mode although the cutoff is decent I can see a bit scattered light as observed by how brightly the freeway signs are lit up
Old 05-20-2013, 06:28 PM   #13
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Wrong forum, no?
D&D is offline   Reply With Quote
FREE to good Yaris - Full size bed conversion Jonkey Australia 3 07-08-2013 12:40 PM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
FEELER: Possible New HID Vendor hydrohopper Cosmetic Modifications (Exterior/Interior) 17 06-11-2010 01:05 AM
My Avatar... Full Size Nutzoids Off-topic / Other Cars / Everything else Discussions 18 08-08-2007 11:51 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
