Old 06-11-2013, 04:48 PM   #1
SECProto
Drives: 2012 Yaris LE
Wiper removal/rubber replacement?
Hey all,
I was given a replacement rubber strip for my 2012 yaris from the dealer, but can't for the life of me figure out how to remove the wiper blade and replace it (dont want to risk damaging it). i've searched this forum and the rest of the internet and even (gasp) the owners manual, but couldnt find it
any help would be much appreciated
Thanks!
SECProto is offline   Reply With Quote
Old 06-11-2013, 06:55 PM   #2
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
They're pretty universal. They slide down toward the bottom of the wipers.
screenprintr is offline   Reply With Quote
Old 06-15-2013, 10:07 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
If you're tying to remove the front wiper arm assembly be careful, the service manual states to remove the main arm bolt, then wrap a cord around the secondary arm and tug forcefully up. I managed to just pull/yank really hard on it and it came loose.
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 08-04-2013, 01:17 PM   #4
2012 YarisSE
Drives: NCP131
Right in the middle of where the wiper blade and wiperarm is located there is a clip. Lift the clip up and slide the blade down. Thats how you can remove the blade.
2012 YarisSE is offline   Reply With Quote
Old 08-07-2013, 01:32 PM   #5
Geoff Peace
Drives: Yaris 1.33 litre 2011
As above if you kook in the centre of the wiper blade the side toward the outer edge of the windscreen you will see a rectangle. This will hinge upward if you apply a screwdriver at its outer edge. Once you have done this, the blade turns at right angles to the arm and slides out. When I bought my car I thought of this and one of the technicians at the dealership showed me how it was done.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 08-08-2013, 09:03 AM   #6
alanwagen
wipe this
Next time, just buy the whole blade, around 5 bucks. They sell them at Wal-Mart, Target, Pep Boys or any auto supply. It just clips on the arm and you do not have to remove the rubber. The nice thing is you get the whole new blade with the proper tension for better performance. You also have the option to upgrade to the RainX blades which are supposed to be longer lasting but I have never tried them. Live and learn, I guess.
Old 08-12-2013, 07:50 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
OEM replacement wiper rubber for our wipers are inexpensive ($6-7 each) at the dealer and seem to outlast even the so-called premium replacements on the market. Rub some Rain-X on the glass (lasts about a year) and you're good to go. Toyota Canada periodically send me parts discount coupons which make those blades even cheaper.
Old 02-04-2015, 01:22 PM   #8
mcastill66
Drives: 2012 Yaris Sedan
What size are the blades on this model?
Thanks
Mike
mcastill66 is offline   Reply With Quote
DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) CTScott DIY / Maintenance / Service 142 06-25-2024 01:47 AM
Rear Wiper Intermittent Delay Timer Mod toy_toronto DIY / Maintenance / Service 36 07-08-2016 08:04 AM
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
Found A Rear Wiper Blade Replacement jeff618 DIY / Maintenance / Service 8 11-03-2011 10:15 PM
Replacement wiper blades fmicle General Yaris / Vitz Discussion 34 03-28-2010 09:58 AM
