Old 07-20-2013, 01:10 PM   #1
JOHNVW
Drives: Toyota Yaris SR 2008
2008 UK 5 door Yaris 1.3 TR Steering wheel/pad.
Hi
Wonder if anyone can help ?
I am trying to remove the steering wheel on my 2008 UK RH drive Yaris TR and cannot see any torx screws under the wheel to undo to release the pad.
There is one hole underneath the horn symbol but no screw under it.
I am stumped !
Wonder if anyone can help?
Thanks John
JOHNVW is offline   Reply With Quote
Old 07-20-2013, 02:53 PM   #2
Does it not have the two screws on the sides of the rear portion of the steering wheel?
Old 07-20-2013, 04:41 PM   #3
JOHNVW
Hi CT,
Unfortunately no it hasn't, there is only 1 hole and it is underneath where the horn symbol is on the rear portion of the steering wheel and there is no screw underneath it.
I have managed to prise the rear portion cover of the steering wheel back and there are no screws visible, but I can see a spring clip on either side under the airbag.
Could these be the holders for the airbag/steering pad ?.
Thank for reply and any help.
Cheers John
PS The car is a UK RH drive Yaris TR 1.3 2008.
Old 07-20-2013, 06:34 PM   #4
Originally Posted by JOHNVW View Post
Hi CT,
Cheers John
It sounds like your is similar to this style, where there are 3 pins that are held in by spring clips.
Old 07-20-2013, 06:40 PM   #5
JOHNVW
Yes I would say you are right, are they easy to remove and replace ?
Cheers John
Old 07-20-2013, 08:58 PM   #6
Cheers John
On the 2012+ US ones that have this style, there is a small plastic trim piece on the side of the rear cover that pops off. That gives you the ability to see under the airbag and to reach in to release those clips.
Old 07-21-2013, 05:28 AM   #7
JOHNVW
There is no detachable trim piece on my cover, trust me to have the most awkward one !!!
I will have to pull the rear cover back and try to release the clips that way.
Cheers John
Old 07-21-2013, 06:36 AM   #8
With the ones that don't have the side cover, but do have the hole on the edge of the pad, you are supposed in insert a tool into that hole to release the tab latch on that end. Once you do, you can lift the pad enough to get at the other latches.
Old 07-21-2013, 04:37 PM   #9
JOHNVW
Hi again CT,
Now you have explained the procedure I removed the airbag and wheel in 5 minutes and fitted the new clockspring.
Many thanks again for your advice.
Cheers John
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering column compatibility between Euro Yaris and US Yaris Micropurchase Third Gen Yaris General Discussion 19 09-17-2012 12:00 PM
2008 5 door Yaris 1.3 TR rear hub replacement. JOHNVW DIY / Maintenance / Service 4 09-16-2012 10:14 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 05:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
