Old 07-24-2013, 03:40 PM   #1
johnbob
johnbob's Avatar
Need dash light help
I wanted an led to illuminate under center switch stack where small catch-all tray is. I used the wire off the radio, green radio illumination wire off back of radio for hot and white/black for common. This would turn light on/off with headlights. This worked fine for a long time. Wire got yanked during a cleaning and my problem is I shorted this wire and while I replaced fuse and got power back, I no longer have dash or speedo illumination once I turn on parking light switch. Lights on dash on when parking switch off / off when parking light switch on. Anyone aware of a relay for dim/bright function of dash lights that perhaps I knocked out? Perhaps same green wire feeds out of radio to dash? Not likely but at loss for answer. Normal operation is when headlight switch in OFF position - bright dash lights, headlight switch in Park/ON position dash lights are toggled to less bright illumination. This is where thought about I killed a relay comes from. Any help appreciated.
Solved by Caineroad - in my process of installing new fuse I had inadvertently rolled the dimmer all the way to off. Nevermind.
johnbob is offline   Reply With Quote
dash light, panel lights, relays, wiring
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
Immobilizer dash light? Red Hot Chilli General Yaris / Vitz Discussion 1 04-19-2012 07:23 PM
Dash light (!) brandypup General Yaris / Vitz Discussion 4 03-30-2012 01:44 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
