#1 |
![]() ![]() Drives: Yaris 1F8 Join Date: May 2013
Small noise form drivers side.. :(
Hi guys iv begun getting this small pop coming from the drivers side front end..
Its mainly when i hit a squarish bump, and or turn towards the right.. I brought it to get checked at an alignement place and they told me everything is fine, they checked everything in the front direction. Can it be the top plate on the strut ?? How do you check that ?? The car has 27000 kms.. thats like 18000 miles.. its practically brand new. We have been getting extremely hot weather here.. do you think its the heat ? Can i apply some lube like silicone lube around all the joints ?? Its not dangerous im sure but it is annoying.. ![]() Thanks !! |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
Maybe the lower control arm bolts? I think there's a recall on that. Mine made a similar noise and that's what it was.
#3 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
if you drive on roads that tend to have salt put down to counter act the snow and ice then you may have a control are bolt starting to corrode off, it will look normal until the head of the bolt finally breaks off.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#4 |
It does sound like the noise is coming from the lower end though.. when i brought it the alignment shop the guys tighten all the bolts with an air gun.. do you think they missed those ones.. ??
#5 |
If they hit them with the impact wrench and they were corroded, one or more may have snapped.
#6 |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
x2
#7 |
Ok i just got the whole front end checked again, 191 motorsports..
everything is perfect.. I noticed though when i drive my car in the rain... i dont hear it anymore..
#8 |
The Quiet Guy
Drives: 2008 Toyota Yaris 4-Door 1.5L Join Date: Jan 2010
I know it's been a few months, but did you ever figure out the problem? I am having the same problem now. I have this weird noise coming from the front drivers side and am also hearing it from the passenger side. I hear the noise when I go over speed bumps and dips as well.
| DIY: Adding LED turn arrows to side mirrors | my2sense | DIY / Maintenance / Service | 10 | 05-28-2012 03:16 AM |
| Drivers side glovebox door. | 07stlYaris | Willing to Buy by private party | 0 | 05-03-2012 06:46 PM |
| how do I replace the drivers side rear view mirror | ath | DIY / Maintenance / Service | 5 | 04-20-2012 12:47 AM |
| Loud vibration/rattling on driver's side? | Ashley87 | General Yaris / Vitz Discussion | 3 | 05-30-2010 03:24 AM |
| Clicking noise when jerking steering wheel side to side/hit bumps left side | eii | DIY / Maintenance / Service | 8 | 03-22-2010 07:46 PM |
