Old 09-10-2013, 01:01 PM   #1
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
Keyless entry beep
Today I installed a keyless entry system from bulldog. It's working just fine but once I connected the parking light flash I came across a peculiarity. When I open the driver's door after remotely unlocking the car I get the tone like the door is open and the key is in the ignition. This only started happening when I connected the parking lights. Any ideas why this is happening?
yours_falsely is offline   Reply With Quote
Old 09-10-2013, 02:11 PM   #2
It sounds like the bulldog may be turning on ignition power to do the parking light flash. If you unlock it and then wait 15 seconds or so before opening it does it still chime?
Old 09-10-2013, 05:27 PM   #3
yours_falsely
No it doesn't. After some time the parking lights go off and it doesn't chime any more. I noticed that shortly after posting.
Old 09-10-2013, 07:12 PM   #4
OK - If the parking lights are on, then you would get the chime when the door is open. If they simply flash quickly and then stay off it won't.
Old 09-10-2013, 07:41 PM   #5
yours_falsely
So it's normal? So the problem is the bulldog keeping the lights on for a few seconds.
Old 09-10-2013, 07:45 PM   #6
Correct
Old 09-11-2013, 09:41 AM   #7
Yeah.. i get this one the 02 civic too (OEM keyless). Basically, when the lights are on and door open, you'd get the chime
I think it is a very bad way to make the lights blink on lock/unlock. OEM Toyota uses the blinkers.
Old 09-11-2013, 11:57 AM   #8
yours_falsely
Is there a wire that could be used that wouldn't activate the chime? It doesn't bother me if I unlock and the lights go off by the time I get to the car, but if I unlock and then immediately open the door it's actually quite annoying.
Old 09-11-2013, 12:08 PM   #9
Not for the tail lights. Check the manual for your keyless to see if you can have it just flash the lights, rather than leaving them on.
Old 09-11-2013, 12:28 PM   #10
yours_falsely
No dice. The unlock flashes the parking lights but it holds the last flash for a few seconds. That's where the problem is. :/
Old 09-11-2013, 02:01 PM   #11
can't you tap it to the hazard flashers instead of the parking lights?
Old 09-11-2013, 03:30 PM   #12
He could if he wants them on instead of the parking lights. The hazards require a negative output from the keyless entry box.
They can be tapped at the black wire on the back of the hazard switch or at the black wire at terminal 17 of connector 4S in the under dash fuse panel.
Old 09-11-2013, 04:34 PM   #13
yours_falsely
I think I'll try that. The under dash fuse panel you're referring to is then one behind the 'sunglass' box above the drivers kick panel, yes?
Old 09-11-2013, 05:10 PM   #14
correct
Old 09-12-2013, 12:01 PM   #15
yours_falsely
Would you happen to have a diagram for said terminal/ connector?
Old 09-12-2013, 12:27 PM   #16
yours_falsely
So tapped into the hazards. Now the light just flash for the same amount of time they were staying on before. I think I would rather deal with the chime.
Old 11-20-2013, 04:53 PM   #17
misterwolfe
What is a clutch?
Drives: 2007 Yaris HB
Send a message via AIM to misterwolfe
Installed a Viper remote start and keyless system on my 2007 Yaris from BestBuy using my employee discount. Viper 4103V + SmartStart GPS Module. Employee cost out door with GeekSquad install was $169 and Viper has a BBY Employee Accomodation of $1 per year of SmartStart/GPS service. Non discount cost would be $400 + Yearly subscription.
When the lights are activated the Yaris thinks you left on your Parking/Headlights. Nothing to worry about. The chime isn't a dealbreaker honestly. The only irritation I have would be the windows roll up too quickly. The Auto window close when pressing lock is an awesome addition, but the Viper keeps pushing for an additional 10 seconds and I'm worried it may burn out my motors. (Returning to GeekSquad to have the timer adjusted, just been too busy to stick to an appointment.)
misterwolfe is offline   Reply With Quote
just bought a Yaris, keyless entry question nmjams In Car Entertainment + Electronics (audio / video / alarm) 9 01-11-2015 11:02 AM
Keyless Entry stopped working but buttons do work! worduphomes In Car Entertainment + Electronics (audio / video / alarm) 5 01-17-2013 09:35 PM
Question about remote keyless entry shela.me DIY / Maintenance / Service 1 08-13-2012 08:01 AM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
