Old 09-25-2013, 03:30 PM   #1
skoya
skoya's Avatar
Drives: Yaris 1.0L
Problem with brake switch
Hi,
Can someone help me?
The Engine light came on.I preformed the diagnostic,and the trouble code was:
P0571-Brake switch "A" circuit.
skoya is offline   Reply With Quote
Old 09-25-2013, 04:51 PM   #2
Do your brake lights work? That code indicates a short in the brake light switch (which is mounted to the brake pedal). The most likely problem is the switch itself.
Old 09-26-2013, 07:16 AM   #3
skoya
skoya's Avatar
Drives: Yaris 1.0L
Yeah,lights are working,nothing special to see.I could pull out the connector and then again back to try and see what happend.I replaced yesterday my braking bulbs with smd led bulbs.May this be a cause or not.Tell me your opinion Scott.
Old 09-26-2013, 09:10 AM   #4
The LED bulbs are almost definitely the cause. The US Yaris ECM does not monitor the brake light switch as aggressively as the European one does.
With the European ECM, the ECM is connected to the feed to the bulbs on the inside of the switch (so it always sees the presence of the bulb, even when the brake pedal is not depressed).
To use the LED brake bulbs you will probably need to use the load resistor, like what is required to use LED turn signal bulbs, with the OEM flasher relay.
Old 09-26-2013, 02:54 PM   #5
skoya
skoya's Avatar
Drives: Yaris 1.0L
Huh,I tought that the bulbs might have cause the problem.Anyway can i leave them there,I mean will this have any issues with the ECM,or should I put the original bulbs back?
Old 09-26-2013, 03:43 PM   #6
It should not cause any problems other than making the check engine light come on.
Old 09-26-2013, 03:46 PM   #7
skoya
skoya's Avatar
Drives: Yaris 1.0L
Ok man thanks
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 09:41 PM
Stock HU Remote Toggle Switch Wiring Question marco_george In Car Entertainment + Electronics (audio / video / alarm) 7 12-13-2010 09:20 PM
LED Install Problem (Tails) Betrivent Cosmetic Modifications (Exterior/Interior) 42 10-29-2010 03:49 AM
Brake problem 1saneguy General Yaris / Vitz Discussion 15 11-24-2008 03:56 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
