Old 10-05-2013, 06:19 PM   #1
vector9mm
Drives: blue 08 hb
lowering = different specs for alignment?
I just lowered my Yaris with Tokico blues (HB3239/HB3240 front)and on rear (HE2993, Part# is for Scion XD) and Eibach pro-kit (8293.140). I'm ready to have wheels aligned and was told by a guy who manages a few auto shops that lowering changes alignment specs. Is this true and if so, what do I have it aligned to? Just drove it a little so far and handles great but ride is rougher than expected.
vector9mm is offline   Reply With Quote
Old 10-05-2013, 06:27 PM   #2
Prokits only lower 1" so an alignment isn't really necessary. If you were going down in the neighbourhood of 2-ish inches, then yes, alignment specs do get thrown out enough to warrant one.
Old 10-06-2013, 10:39 AM   #3
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
Lowering WILL throw out your alignment. Your camber and toe will need to be adjusted even if minor, your rear torsion axle should be fine. its much cheaper than replacing tires more often.
You can align your car to factory specs it will be fine.
Scubaru Steve is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Lowering or Not? chrisj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-06-2010 02:34 PM
Progress Lowering Springs!!!!!! Jkiech Items for Sale by private party 24 09-06-2009 12:57 AM
