Old 12-08-2013, 11:53 PM   #1
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
passenger side rear wheel sitting higher than the rest...
hai guise, i've got a bit of a problem...
so my gen3 is sitting on s-techs, and normally i've got about a half inch gap between the tires and the wheel well. however, a few nights ago, i noticed that my passenger side rear wheel is sitting a whole inch higher than the other wheels! so i'm just trying to figure out what's going on with it? what can cause this, and how can i fix it? the only thing i can think of is maybe the dealership messed something up when i took it in for service. anyone have any ideas?
b20vteg is offline   Reply With Quote
Old 12-09-2013, 06:20 AM   #2
Look at the rear spring perches. When they put it on the lift on of the rear springs may have move out of position while the axle beam was hanging.
Old 12-09-2013, 11:15 PM   #3
b20vteg
no show, no go :(
b20vteg's Avatar
good call! boy am i glad you're always here to help. definitely will check that, thanks! :D
Old 12-10-2013, 01:44 AM   #4
b20vteg
no show, no go :(
b20vteg's Avatar
ok, so here's the weird thing: i went out to check the rear spring perch, and the spring seems to have settled back down... :S
is it possible that these things can fix themselves?
Old 12-10-2013, 06:42 AM   #5
It is possible. Driving it with them partially out of place they may have popped back into place on the perches, which is better than popping out and rolling away.
Old 12-10-2013, 07:05 AM   #6
b20vteg
no show, no go :(
b20vteg's Avatar
...they may have popped back into place on the perches, which is better than popping out and rolling away.
lol yes, definitely much better than them popping out and rolling away...
Old 12-21-2013, 11:54 PM   #7
manakorin
manakorin
Drives: 2010 yaris
Send a message via AIM to manakorin
Glad it worked out for you.
rhinoplasty in atlanta
manakorin is offline   Reply With Quote
Rear wheel bearing LeetViet DIY / Maintenance / Service 1 08-29-2012 07:41 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 07:54 PM
