Old 12-24-2013, 06:42 AM   #1
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
[Fitment Report] 185/65R15 w/ H&R Sport springs (1.25" drop)
SUCCESS!
No rubbing 100%.
More details to follow.
Mittelklasse is offline   Reply With Quote
Old 12-24-2013, 06:47 AM   #2
Mittelklasse
Problem, officer?
FRONT:
(Right-hand side)
(Left-hand side)
REAR:
Old 12-24-2013, 07:40 AM   #3
sex
sex's Avatar
Drives: 09 5DR
Why choose 65 vs 60?
Old 12-24-2013, 08:45 AM   #4
Mittelklasse
Problem, officer?
The 65 profile offers taller sidewall. (4.7" vs 4.4")
Benefits are much lower noise, vibration, harshness, and better fuel economy.
Old 12-24-2013, 04:19 PM   #5
mr_miles
Drives: 2013 Yaris
that's a lot of sidewall! bet it rides smooth though. :D How much does fuel economy improve?
On a side note - 225/50/15's on a 10 inch wide wheel do NOT fit under the rear of a yaris when you're lowered to less than 3 inches of ground clearance. Just in case anyone is curious.
Old 01-01-2014, 07:38 AM   #6
Mittelklasse
Problem, officer?
I've just went through 2 tanks since the replacement, and the results are in.
(Note: my old set of tires were of size 195/55R15)
FUEL ECONOMY
[Averaged 50/50 Highway/Urban]
Before: 13.76 km/L (32.4 MPG)
After: 15.46 km/L (36.4 MPG)
PERFORMANCE
Highway speed (>60 MPH) acceleration is noticeably improved. The car feels a bit more torquey.
At lower speed and take off, it isn't suffered much either. 0-60 time is about 0.2 second slower.
HANDLING
Steering feel and high speed stability are improved due to more negative scrub radius.
However, Turn-in and low-speed cornering are worse a bit. (But still better than stock Yaris)
More negative camber should be able to compensate. (ATM I'm running -1.00 deg.)
Comfort and quietness are very, noticeably better. The ride can be said to be "Rubbery, yet firm".
The car became more like European mini highway cruiser.
Old 01-10-2014, 09:53 AM   #7
Lars
Yaris beginner
Drives: Yaris XP9F
I can understand improvements in fuel economy, noise, comfort... but better high speed handling?? By increasing tire sidewall?? Sorry, I'm not buying that.
Lars is offline   Reply With Quote
Old 01-10-2014, 01:10 PM   #8
Mittelklasse
Problem, officer?
Originally Posted by Lars View Post
(...) better high speed handling?? By increasing tire sidewall?? Sorry, I'm not buying that.
I used the term "stability". The car tracks straight, and negates crosswind and road irregularities better.
(More angular momentum + more negative scrub radius)
Overall handling, turn-in, etc. is worse than shorter sidewall, of course.
Old 01-13-2014, 03:30 AM   #9
Lars
Yaris beginner
Drives: Yaris XP9F
^ Oh ok... but it was under the topic "handling", so it kinda got me wondering what you meant. That clarifies :)
One question for you! Your front strut bar, did you have to drill or does it use the two holes already existing? I wanted to try one of those but without drilling. Did you notice a nice improvement?
On my previous VW Golf IV I bought a strut bar (I had to drill though) and the improvement was extraordinary! Best money I spent on that car!
Old 01-13-2014, 03:31 AM   #10
Lars
Yaris beginner
Drives: Yaris XP9F
BTW, your car looks real nice, I have a set of H&R springs and some wheel spacers waiting for spring time. I hope it will look as nice as yours :)
Old 01-16-2014, 05:10 AM   #11
Mittelklasse
Problem, officer?
My strut bar is a bolt-on, no drilling required.
As of an improvement the car is more 'stable' (again!) at high speed, but in an understeer fashion.
The chassis seems to resist any directional changes made and just wants to go straight.
So, I think it is advisable to install together with a rear sway bar.
Danke schoen!
I used to ride on 195/55s. Those look and handle definitely better.
But, since I have to work up-country more often,
I should better go with such tire with largest possible sidewall and low rolling resitance.
Old 01-16-2014, 07:57 PM   #12
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
Your Yaris looks awesome - I love those stock alloy wheels from the mid 2000's - I want a set like that for my 2013 Yaris - Think there is an issue with the tire pressure monitoring sensors and using older rims...not sure but I'm along way off from new rims. Those are beautiful, just fantastic! The blue looks awesome, too - !
yougojay is offline   Reply With Quote
Old 06-22-2014, 04:46 PM   #13
amfareed
Drives: yaris sedan 1.3 2008
I bought the same size for my yards sedan 2008...what PSI (tyre pressure) you recommend?
when I use 30 PSI the car is little bit loose...do you recommend higher PSI?
Thanks
amfareed is offline   Reply With Quote
Old 07-06-2014, 10:38 AM   #14
Mittelklasse
Problem, officer?
Thanks
I set mine at 35 PSI front / 32 PSI rear.
To me it offers a good balance between handling, ride comfort, and fuel economy.
205/45/17 planning to lower with H&R Sport Springs aeroDynamic Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-14-2012 11:49 PM
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 01:18 AM
KSport GT Springs 2 Inch drop all around YenOfIrrelevent Items for Sale by private party 27 05-02-2011 01:03 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
