Old 01-07-2014, 08:39 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
summer wheels ...please vote
Need help to pick one...
[ATTACH][ATTACH]F139-Hayaku-_Concave_-Satin-Grey.jpeg[/ATTACH][/ATTACH]
PS they will be 15 inches with 195 55 15
Old 01-07-2014, 08:47 PM   #2
Mongoose7
Drives: 2007 Yaris HB
What car ? What color car ??
Mongoose7 is offline   Reply With Quote
Old 01-07-2014, 09:39 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Old 01-07-2014, 11:12 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Should've made this a poll.
I'd choose the 1st one only because it's more of a classic design and classics never die.
Looks like Varrstoens.
Old 01-08-2014, 12:08 AM   #5
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
#1
Old 01-08-2014, 12:09 AM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
#1 fo sho
Old 01-08-2014, 12:10 AM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
Of the 3 wheels, I like #1.
Old 01-08-2014, 02:19 AM   #8
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
# 1!!
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 01-08-2014, 07:06 AM   #9
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Option one for sure te-37 reps!
Check my build thread and youll see what they look like on
Old 01-08-2014, 11:37 AM   #10
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
#1
Old 01-08-2014, 11:41 AM   #11
#1, but only if it weighs 16lbs or less.
Old 01-08-2014, 02:24 PM   #12
Brett!
Drives: 2010 3D base
option #1 is legit, assuming it comes in a 4lug design? IF so link me so I can buy them, too.
Brett! is offline   Reply With Quote
Old 01-08-2014, 06:39 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yes 4x100 40 et also 54.1 bore is possible or standard 73 then u need hub rings.
I will be getting them direct from fastwheels at cost around 100 $ per rim Canadian maybe less I know that they have some models at clearance too very cheap.
Old 01-08-2014, 06:48 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
http://tires.pmctire.com/ent/
link to wheels
Old 01-08-2014, 07:22 PM   #15
Chances are they are not true 4x100. Cheap wheels are almost always double drilled to accommodate both 4x100 and 4x114 bolt patterns. Bonus if they are indeed single drilled.
That is only a link to the wheel selector.
Old 01-08-2014, 07:54 PM   #16
Viperoni
Drives: 2005 Toyota Echo
If you're doing 15's, definitely #1.
2006 Saturn Ion Redline
Old 01-08-2014, 08:34 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
http://tires.pmctire.com/ent/wheels....723873]Chances are they are not true 4x100. Cheap wheels are almost always double drilled to accommodate both 4x100 and 4x114 bolt patterns. Bonus if they are indeed single drilled.
That is only a link to the wheel selector.[/QUOTE]
Old 01-08-2014, 08:38 PM   #18
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
If u go to pmc web pg they have a huge selection of wheels ....and yes 4 bolt only no multy patern .
MECA Mad Scientist on Wheels @ Best Buy Colonial Summer Slam - 6/11/11 for Charity H3LlIoN Mid-Atlantic 4 06-10-2011 05:53 PM
New Wheels for Summer VOlk Racing inside!! Steven Dionne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-07-2011 11:07 PM
JDM Wheels and some track wheels/tires jdmekcivic Items for Sale by private party 10 09-08-2009 12:27 PM
MR-S wheels kngrsll Items for Sale by private party 7 07-07-2009 01:08 PM
