Old 01-19-2014, 07:12 PM   #1
venezbras2013
Drives: 2012 Yaris SE
Not sure what to do with tire size, need some input
I got my wheels already about a month ago, they are Enkei GTC01 17x7 +38mm offset. I will be lowering my car with TRD lowering springs but I am not sure if I should go the safest way and put on 205/40R17 or if I can fit meetier tires and go for the 205/45R17..... any input and pictures will be greatly appreciated :)
venezbras2013 is offline   Reply With Quote
Old 01-20-2014, 03:32 PM   #2
205/45 might be a little fat and cause some rubbing. Are you prepared to put a little negative camber on the front or rear, or roll your fenders if needed?
Old 01-21-2014, 11:43 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
The height of the 205/45/17 is no problem with a TRD drop. But with ET38, you may get some rubbing up front.
Old 01-21-2014, 10:28 PM   #4
venezbras2013
Thanks guys!
Kimona: you think that with 205/40's I would still rub with an ET38?
should I leave the suspension at stock height? would this help at all?
Thanks.
Old 01-21-2014, 11:34 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by venezbras2013 View Post
Thanks guys!
Thanks.
I say just lower the car with 40s I would bet they will work fine all depends how low anything from 1 to 1.5 should be fine ...like trd springs .....just see what the over all diameter is of the wheels in comparison to stock and over all width .....just load ur car with few heavy ppl ..lol and get an idea.
Best winter tire size SECProto Third Gen Yaris General Discussion 3 12-01-2012 11:37 PM
Tire size change bsg916 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-30-2012 11:06 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 03:06 AM
what tire size fits best for 15x6 rims? savister Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-26-2010 09:37 PM
Tire size blueskana Tracking, Racing, Auto-X Forum 0 08-12-2007 10:04 PM
