Old 01-20-2014, 12:38 PM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Replacing the battery in the key
2008 sedan, used to be i could activate the lights and locks from a good distance away now i have to be standing almost next to the car for the key to unlock the doors, after 7 years i'm assuming the battery in the key is finally needing replacement. i'm also assuming its just a matter of splitting the key taking out the old battery and installing a new one..
What battery am i looking for?
Thanks.
Nevermind ..i should have checked first.
http://www.yarisworld.com/forums/showthread.php?t=40684
Have Yaris will travel..
Old 01-20-2014, 12:53 PM   #2
i'm still on my original battery, and it has not failed me so far.
I'm not sure if the chip key does something to the battery.. it shouldn't though. But it also depends where you are.. these keyless frequencies seems to be easily disrupted.
I'm able to activate it inside the office at work, while it wont do 10 cars length in a parking lot.
Old 01-20-2014, 02:16 PM   #3
The transponder chip is a separate device from the remote.
You do just split the case to get at it, and the battery is a CR2016.
Old 01-20-2014, 05:40 PM   #4
jambo101
jambo101's Avatar
Transponder? Will it need a replacement battery at some point?
Old 01-20-2014, 05:58 PM   #5
No. It is a passive transponder, which gets powered by the radio frequency from the reader which is built into the ignition switch assembly.
Old 01-20-2014, 08:43 PM   #6
auxmike
auxmike's Avatar
So glad my 2008 doesn't have that. I put in the $49 Viper keyless entry....
Also, I can get my keys made at the hardware store for about $2.50. No transponder chip!
Help with replacing 2 button key remote hotnoodle DIY / Maintenance / Service 22 12-18-2016 06:26 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
Smart key entry - battery problems. red-demon85 DIY / Maintenance / Service 5 10-24-2013 06:28 AM
Replacing automatic open and lock key. junorico24 DIY / Maintenance / Service 5 07-23-2012 01:40 AM
