Old 01-21-2014, 04:05 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Squeezing some serious rubber,SM setup
Test fitted my new setup for this season.... 275/35-15'' Hoosier A6 for the front! 225s going on the rear. Front wheels are 15x9 with a 15 offset, rears 15x8 with a 25 offset.
File Type: jpg 1613868_10202598639099913_163278443_n.jpg (54.7 KB, 210 views)
Ptuning.com
Old 01-21-2014, 04:39 PM   #2
RJay
Drives: 2002 Toyota Yaris T-sport
Fat. Very Fat. Rubber.
How much power are you putting onto those and what kind of clutch are you running?
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-21-2014, 04:41 PM   #3
Nice. Are you reworking the fenders to accommodate?
Old 01-21-2014, 04:50 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
320whp+ . ACT 6 puck
Ptuning.com
Old 01-21-2014, 04:55 PM   #5
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I am most likely getting shorter coil springs in the front, so I can raise the perch ( so tire doesnt touch with more camber). I need to run more negative camber with these tires, so they will be in at the top more than it is now.
Ptuning.com
Old 01-21-2014, 04:56 PM   #6
RJay
Serious power indeed. And I thought you wouldn't be running some ole stock clutch with that rubber needed.
Old 01-21-2014, 08:09 PM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Insanity. I'm assuming this is for track use, and not tight-course autocross?
Old 01-21-2014, 08:09 PM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You will be able to easily pick him out of a crowd. He will be the one with the seam splitting left leg and normal sized right one....hahahaha
Old 01-21-2014, 08:44 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
It is intended more for autocross, and circuit cross style ( standstill start, one hot lap) time trials. The good thing about being in the DC region, is that I get to Compete with the national SMF champion and other really strong competitors. 275s up front is my only chance to be a front runner.
Ptuning.com
Old 01-22-2014, 02:58 AM   #10
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Thats awesome, thats the same tire size I was going with this year. Good luck man. I hope to make an event up north once this year. I will be in FSP probably.
-Derrick-
Old 01-22-2014, 07:03 AM   #11
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
so nasty. Are those CCW's too?
Old 01-22-2014, 06:05 PM   #12
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Avid 12 is the wheel. I came across a crazy deal, $219 for all 4 brand new. Reason; wheel paint color was off. I did an alignment today and dialed in a good starting point for camber, the tire sits darn near flush. The picture above was with a 3mm spacer, which is no longer being used. The inside of the tire clears the coilover body by about 4mm. These wheels fit PERFECTO
Ptuning.com
Old 01-22-2014, 09:03 PM   #13
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Those are some phat ass wheels.
I'm guessing you rub like crazy on rough roads?
Old 01-22-2014, 09:57 PM   #14
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I'm guessing you rub like crazy rough roads?
This wheel and tire combo will probably never see a public road, so I'm not to worried about rubbing issues. I run 450lb springs up front along with a 300lb sway bar, so far that fender to tire gap has never closed.
Ptuning.com
Old 01-24-2014, 05:35 PM   #15
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
A 320whp Yaris in Virginia. I need to see it !
vaironl is offline   Reply With Quote
Old 01-24-2014, 07:26 PM   #16
It's not a Yaris.
Old 01-24-2014, 07:29 PM   #17
vaironl
vaironl's Avatar
It's not a Yaris.
DAM IT!!!!
I'm beating myself up for missing that.
Old 01-24-2014, 07:30 PM   #18
Hahaha. It's still power by a 1NZ though so it counts.
)) Steering wheel hub setup (( aucorium Cosmetic Modifications (Exterior/Interior) 4 04-30-2011 04:09 PM
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
New "milder" Setup Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-26-2010 10:08 AM
N/A setup Maitre_Te_Te Performance Modifications 22 12-07-2009 03:24 AM
Yaris 2001 - serious problem adnanmalik General Yaris / Vitz Discussion 10 06-19-2006 08:59 AM
