Old 01-25-2014, 01:41 PM   #1
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
very notchey temp dial
I had to take apart my dials to trim some of the plastic away bc I bought smd led for my interior. Well I got my dials back together but the temp gauge has a notch half way through cold, right in The middle of cold/hot and half way through hot. What did I do wrong?
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 01-25-2014, 03:42 PM   #2
Are the notches there when the cable is disconnected from the control?
Old 01-25-2014, 04:03 PM   #3
soldout
soldout's Avatar
Yes.
Old 01-25-2014, 04:07 PM   #4
Yes.
OK. the gear train is off. If you turn it at all while it is apart that occurs. You will have to pull it back apart again and experiment with it. I haven't messed on up in a while, but I don't recall there being alignment marks, so it's a bit of a hassle to get it back right. After the first time that I did that I learned to mark the gears when I took one apart.
Old 01-29-2014, 03:16 PM   #5
soldout
soldout's Avatar
Thanks scott, im pretty mechanically inclined myself but I could not for the life of me figure out why the dial was notchey. I took it apart and put it back together a few times and now the notch is gone, weird! The dial had full range and motion just notchey. Everything is good now though thanks.
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 12:20 AM
Tach Installed & Temp Wheels On justjesus Off-topic / Other Cars / Everything else Discussions 4 02-07-2009 01:26 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
Auto dim mirror with compass and temp Violin Cosmetic Modifications (Exterior/Interior) 7 08-30-2006 06:48 PM
